Want proof that low band apply works?
#1451683
06/12/13 02:07 PM
06/12/13 02:07 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Well if anyone ever wondered if a low band apply valve body works, I am here to tell you... it does... and it doesn't. I believe I have abused my 727 with about as much as one could do. 3700lb car 2.76 gear (read VERY HIGH load in the trans) Trans Brake launches 8psi of boost at 4400rpm Car ran 10.67@127.71 if that gives you an idea of power. Trans started "shuttering" on launch, and later developed a slip during the 1~2 shift. Once in 2nd gear it was fine, but had a little "flare" on the shift. Then started making some driveshaft speed grinding noises in 2nd/3rd during coast down. Took the trans apart last night. First of all one of the exhaust hangers were broke, so it was hitting the shock (part of my clunk). Second of all, the trans mount was broke (even more part of my clunk). Decided to take the trans apart anyway, just to make sure everything looked good. Lots of metal in the pan, got down to the low roller (sprag) and it was destroyed. Fortunatly it didn't hurt the case. Now I have a tranzact valve body (trans brake) with low band apply. I obviously made several mid-high 10 second passes on a broken sprag, so the the LBA definately kept the trans from coming apart. However, the LBA did NOT keep the trans from destroying the low roller. Take what you will from my experiance, but my feeling is the following. 1) The LBA function will keep you safe. I think this experiance proves that. 2) The LBA will NOT prevent sprag failure. If you want your trans to live a long happy life, you still need a good sprag regardless of if your valve body has LBA or not. Anyway... just wanted to share. Getting parts tonight, back together tomorrow, off to Stanton this weeekend to make some more runs. Upgraded the car to 3.23 gear (from a 2.76), and I also bought 275/60's for it (replacing the warn our 255/60's). We'll see if we can get this ol' heap below the 10.50 mark!!!!
Re: Want proof that low band apply works?
[Re: dizuster]
#1451689
06/12/13 05:58 PM
06/12/13 05:58 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Coan. And a new Kevlar front band this time.
Good choice on the sprag , bad choice for the band.
Kevlar is not a good band to use on the front , it's fine on the rear , a solid red lined would be better for the front.
This is what I was told by Cope .
[Re: Twostick]
#1451692
06/12/13 08:19 PM
06/12/13 08:19 PM
dizuster
Oakland, MI
If you were whaling on it from a standstill in Drive, you could still do that damage. LBA only works in manual Low.
Kevin
It's a full manual valve body. I don't have "drive".
Broke with the lba applied.
[Re: dusturbd340W5]
#1451694
06/13/13 03:14 PM
06/13/13 03:14 PM
dartman366
Mt. Vernon, Ohio
Kevlar is no good on the front go with the red lining and the Coan sprag is great I have used a number of them.
Can someone explain to me why the kevlar intermediate band is no good?
[Re: JohnRR]
#1451697
06/13/13 06:01 PM
06/13/13 06:01 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You'll see more instances of glazing with the Kevlar band than the red.
[Re: John_Kunkel]
#1451698
06/13/13 08:14 PM
06/13/13 08:14 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
correct the material is to hard and becomes glazed very fast
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Leigh]
#1451700
06/14/13 03:11 AM
06/14/13 03:11 AM
dizuster
Oakland, MI
Got the Trans back together tonight. Unfortunately I had to put a kevlar band in it because it was all I could get on short notice. Got the super sprag in it...and just in case anyone is wondering, it is most definitely not designed for a push button Trans case. Took some engineering and machine work to make it fit. Off to Stanton this weekend as long as the new tires fit and the Trans shifts tomorrow when I put fluid in it.
[Re: dizuster]
#1451701
06/14/13 07:11 AM
06/14/13 07:11 AM
Posts: 1,629 pa
572charger
pa
kevlar band is fine there is one in my trans it has 1million miles and 4000 9 second runs on it LOL red ft band would go away after some 300hp no2 shots ?? just my experiance not to start a wizzing contest, can ya still get the kevlar band? mabe crt will chime in ??
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
