Want proof that low band apply works? #1451683
06/12/13 02:07 PM
06/12/13 02:07 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Well if anyone ever wondered if a low band apply valve body works, I am here to tell you... it does... and it doesn't.
I believe I have abused my 727 with about as much as one could do.
3700lb car
2.76 gear (read VERY HIGH load in the trans)
Trans Brake launches
8psi of boost at 4400rpm
Car ran 10.67@127.71 if that gives you an idea of power.
Trans started "shuttering" on launch, and later developed a slip during the 1~2 shift. Once in 2nd gear it was fine, but had a little "flare" on the shift. Then started making some driveshaft speed grinding noises in 2nd/3rd during coast down.
Took the trans apart last night. First of all one of the exhaust hangers were broke, so it was hitting the shock (part of my clunk). Second of all, the trans mount was broke (even more part of my clunk).
Decided to take the trans apart anyway, just to make sure everything looked good.
Lots of metal in the pan, got down to the low roller (sprag) and it was destroyed. Fortunatly it didn't hurt the case.
Now I have a tranzact valve body (trans brake) with low band apply.
I obviously made several mid-high 10 second passes on a broken sprag, so the the LBA definately kept the trans from coming apart.
However, the LBA did NOT keep the trans from destroying the low roller.
Take what you will from my experiance, but my feeling is the following.
1) The LBA function will keep you safe. I think this experiance proves that.
2) The LBA will NOT prevent sprag failure. If you want your trans to live a long happy life, you still need a good sprag regardless of if your valve body has LBA or not.
Anyway... just wanted to share. Getting parts tonight, back together tomorrow, off to Stanton this weeekend to make some more runs.
Upgraded the car to 3.23 gear (from a 2.76), and I also bought 275/60's for it (replacing the warn our 255/60's).
We'll see if we can get this ol' heap below the 10.50 mark!!!!
Re: Want proof that low band apply works? [Re: dizuster] #1451684
06/12/13 02:07 PM
06/12/13 02:07 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Parts...
Re: Want proof that low band apply works? [Re: dizuster] #1451685
06/12/13 02:13 PM
06/12/13 02:13 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
hogwash , that trans would have lived another 1000 passes like that ....
Are the splines stripped off where the front planet mounts also ?
Re: Want proof that low band apply works? [Re: JohnRR] #1451686
06/12/13 02:23 PM
06/12/13 02:23 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
LOL...maybe it could have... but 2nd gear wasn't happy. I did have the finest in used bands in it... can't possibly see why it wouldn't live...
Planetary's were perfect. Actually it didn't hurt much. Needs a new sprag, new 2nd gear band, and one plastic thrust washer. That's it.
Re: Want proof that low band apply works? [Re: dizuster] #1451687
06/12/13 02:24 PM
06/12/13 02:24 PM
JohnRR Offline
JohnRR  Offline
Are you putting in a Coan or A+A sprag ? Anything else is a waste of time and money.
Was your front band Kevlar ?
Re: Want proof that low band apply works? [Re: JohnRR] #1451688
06/12/13 05:13 PM
06/12/13 05:13 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Coan. And a new Kevlar front band this time.
Re: Want proof that low band apply works? [Re: dizuster] #1451689
06/12/13 05:58 PM
06/12/13 05:58 PM
JohnRR Offline
JohnRR  Offline
Good choice on the sprag , bad choice for the band.
Kevlar is not a good band to use on the front , it's fine on the rear , a solid red lined would be better for the front.
This is what I was told by Cope .
Re: Want proof that low band apply works? [Re: JohnRR] #1451690
06/12/13 07:30 PM
06/12/13 07:30 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If you were whaling on it from a standstill in Drive, you could still do that damage. LBA only works in manual Low.
Kevin
Re: Want proof that low band apply works? [Re: JohnRR] #1451691
06/12/13 07:37 PM
06/12/13 07:37 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Kevlar is no good on the front go with the red lining and the Coan sprag is great I have used a number of them.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Want proof that low band apply works? [Re: Twostick] #1451692
06/12/13 08:19 PM
06/12/13 08:19 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Kevin
It's a full manual valve body. I don't have "drive".
Broke with the lba applied.
Re: Want proof that low band apply works? [Re: dizuster] #1451693
06/13/13 02:41 PM
06/13/13 02:41 PM
arizona
stockerbill Offline
stockerbill  Offline
arizona
I Love That Car !! What engine do you run in it?
Re: Want proof that low band apply works? [Re: dusturbd340W5] #1451694
06/13/13 03:14 PM
06/13/13 03:14 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Can someone explain to me why the kevlar intermediate band is no good?
Re: Want proof that low band apply works? [Re: dizuster] #1451695
06/13/13 05:12 PM
06/13/13 05:12 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I believe my 60' was going because the sprag was going bad but I mistook it for tire slip and soon after I lost 1st pulling into the pits on my way to tech in at the track.I have the coin super sprag now.
Re: Want proof that low band apply works? [Re: dartman366] #1451696
06/13/13 05:33 PM
06/13/13 05:33 PM
JohnRR Offline
JohnRR  Offline
The kevlar band works for a while but it doesn't hold up well to stopping a spinning drum , after a while it will begin to slip. That's why it's ok on the rear drum, the rear drum only tries to turn when going in reverse and the band grabs ahold it it before it can get any speed going.
Oh course now someone will come on with a HOGWASH , I have 1,000,000 passes and 500,000 street miles on a Kevlar band , it's been in there since the dawn of time and I've never had an issue .
Re: Want proof that low band apply works? [Re: JohnRR] #1451697
06/13/13 06:01 PM
06/13/13 06:01 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
You'll see more instances of glazing with the Kevlar band than the red.
Re: Want proof that low band apply works? [Re: John_Kunkel] #1451698
06/13/13 08:14 PM
06/13/13 08:14 PM
Kissimmee Fl.
Kissimmee Fl.
correct the material is to hard and becomes glazed very fast
Re: Want proof that low band apply works? [Re: dusturbd340W5] #1451699
06/13/13 09:17 PM
06/13/13 09:17 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I put 500 passes on an iSonnex Kevlar band in the mid eighties. The oem front drum, wore to the exact band pattern. You could still read the logo and part number on the band. So yeah, there was some frictional coefficient compatibility issues happening. I kept the band for a core, I should dig it out, and post a pic of that thing.
Re: Want proof that low band apply works? [Re: Leigh] #1451700
06/14/13 03:11 AM
06/14/13 03:11 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Got the Trans back together tonight. Unfortunately I had to put a kevlar band in it because it was all I could get on short notice.
Got the super sprag in it...and just in case anyone is wondering, it is most definitely not designed for a push button Trans case. Took some engineering and machine work to make it fit.
Off to Stanton this weekend as long as the new tires fit and the Trans shifts tomorrow when I put fluid in it.
Re: Want proof that low band apply works? [Re: dizuster] #1451701
06/14/13 07:11 AM
06/14/13 07:11 AM
pa
572charger Offline
572charger  Offline
pa
kevlar band is fine there is one in my trans it has 1million miles and 4000 9 second runs on it LOL red ft band would go away after some 300hp no2 shots ?? just my experiance not to start a wizzing contest, can ya still get the kevlar band? mabe crt will chime in ??
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Want proof that low band apply works? [Re: 572charger] #1451702
06/14/13 11:09 PM
06/14/13 11:09 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
you run 10.70 in a 3700lb car with a 2.76 gear? I HAVE GOT TO HEAR ABOUT THE MOTOR!
