440 aluminum intake opinions #1450870
06/10/13 10:38 PM
06/10/13 10:38 PM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
I have a '69 roadrunner with a 440 in it and I want to get an aluminum dual plane intake manifold for it. I want to also put my air grabber back on the car. Can anyone tell me which dual plane will sit low enough to allow room for the air grabber and air cleaner.
Thanks.
Re: 440 aluminum intake opinions [Re: markrr] #1450871
06/10/13 11:52 PM
06/10/13 11:52 PM
Missouri
3
3_RTs Offline
3_RTs  Offline
Missouri
I have just recently purchased the Edelbrock CH4B aluminum intake. Basically it is an aluminum version of the stock intake. I wanted to be sure that my air grabber fit properly on my air cleaner.
Re: 440 aluminum intake opinions [Re: 3_RTs] #1450872
06/10/13 11:55 PM
06/10/13 11:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The CH4B is taller than stock , I used to recommend it ASSuMEing it was the same as stock because it was NHRA approved.
The ONLY intake that is the same as a stock cast iron is the original M1 dual plane .
Re: 440 aluminum intake opinions [Re: JohnRR] #1450873
06/11/13 12:09 AM
06/11/13 12:09 AM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
"Original M1". Is this the part that's still being produced now or the older discontinued one?
Re: 440 aluminum intake opinions [Re: markrr] #1450874
06/11/13 12:17 AM
06/11/13 12:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
older discontinued , the current is a rebadged Ebrock RPM
Re: 440 aluminum intake opinions [Re: JohnRR] #1450875
06/11/13 12:19 AM
06/11/13 12:19 AM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
Thanks.
Re: 440 aluminum intake opinions [Re: markrr] #1450876
06/11/13 08:24 AM
06/11/13 08:24 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
This one will fit under your air grabber...
Coming soon!!!!
Re: 440 aluminum intake opinions [Re: Mr.Yuck] #1450877
06/11/13 02:09 PM
06/11/13 02:09 PM
dogdays Offline
dogdays  Offline
To restate, the CH4B is NOT an aluminum version of a stock intake. It is better.
R.
Re: 440 aluminum intake opinions [Re: JohnRR] #1450878
06/11/13 11:17 PM
06/11/13 11:17 PM
Missouri
3
3_RTs Offline
3_RTs  Offline
Missouri
JohnRR, do you know how much taller the CH4B is than stock?
