How to remove SB oil filter mounting plate? #145075
11/03/08 01:48 PM
11/03/08 01:48 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
I was at the junkyard yesterday and finally got the bolt/stud/tube thing out with a 3/8" extension, but how am I supposed to remove the plate that is behind it? I tried prying, twisting, without anything working!
TIA.
Re: How to remove SB oil filter mounting plate? [Re: sharpie] #145076
11/03/08 02:03 PM
11/03/08 02:03 PM
IMGTX Offline
IMGTX  Offline
I have had good luck with a small chisel/screwdriver in the center hole. Drive it in at an angle between the plate and the block.
Work around the inside in a circle. Don't jamb it in one side or you may bend the plate. Work it around and it will eventually break the seal on the outside edge.
While you are at it add a few extra holes for the oil to flow through the plate like I have found on the HD engines. The weakest link for the everyday small block is the restrictive oil system IMHO.
Re: How to remove SB oil filter mounting plate? [Re: sharpie] #145077
11/03/08 02:21 PM
11/03/08 02:21 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
You can buy a brand new kit for 35 dollars....
Re: How to remove SB oil filter mounting plate? [Re: IMGTX] #145078
11/03/08 04:38 PM
11/03/08 04:38 PM
& if you are interested in more SB oiling info go here. www.moparchat.com then scroll down to & click on circle track chat then checkout Sanborns oiling mods that are in a sticky at the top of the page. It might take you several hours to sort thru all of it but he is one of the foremost SB oiling experts in the country & if your eng is being built up from scratch right now his info will benefit you & I used alot of his mods on a BB as the oiling system is routed pretty similar.
Re: How to remove SB oil filter mounting plate? [Re: Dart 340] #145079
11/03/08 07:54 PM
11/03/08 07:54 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
where? I can't find one either on Mancini or Summit!
Re: How to remove SB oil filter mounting plate? [Re: sharpie] #145080
11/04/08 03:11 PM
11/04/08 03:11 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
I'd really like to find out!
Re: How to remove SB oil filter mounting plate? [Re: sharpie] #145081
11/04/08 03:14 PM
11/04/08 03:14 PM
NY usa
540challenger Offline
NY usa
i think you can still get them thru the dealer
Re: How to remove SB oil filter mounting plate? [Re: sharpie] #145082
11/04/08 03:26 PM
11/04/08 03:26 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
There is a guy in Minneapolis that I bought mine from. Give me 5 to find the link.
Re: How to remove SB oil filter mounting plate? [Re: Dart 340] #145083
11/04/08 03:36 PM
11/04/08 03:36 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I found his e-bay store. His name is Scott Vandais
He has a shop in Minneapolis. I have bought a bunch
of things from him. All worked out ok.
http://motors.shop.ebay.com/merchant/mopartsdealer
Re: How to remove SB oil filter mounting plate? [Re: Dart 340] #145084
11/04/08 03:40 PM
11/04/08 03:40 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Here we go, this is his web site and store.
Boy that was the long way home......
http://www.marketworks.com/StoreFrontProfiles/default.aspx?sfid=92390
Re: How to remove SB oil filter mounting plate? [Re: Dart 340] #145085
11/04/08 03:53 PM
11/04/08 03:53 PM
P5249320 thats the Gskts to service the rt angle adapter which are the same as yoy neeed also there should be no adapter plate on the block with a 90adapter what are you trying to do here? the plate is available from mopar or was last time i checked you need that Pn too?.Rt angle oil fiter adapter Kits aint no 35.00 either they are 139.95 from Mancini.
Re: How to remove SB oil filter mounting plate? [Re: Dart 340] #145086
11/04/08 03:54 PM
11/04/08 03:54 PM
scratchnfotraction Offline
I got a good used one you can have if ya want it
has the 4 extra holes drilled in it already
Re: How to remove SB oil filter mounting plate? [Re: scratchnfotraction] #145087
11/04/08 04:39 PM
11/04/08 04:39 PM
Pn 2402103 14.55 from www.moparpartsamerica.com that the last freebie from me iam in the buisnees of selling pnS and locating.ad to soon be on here.
Re: How to remove SB oil filter mounting plate? #145088
11/04/08 04:59 PM
11/04/08 04:59 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I'd just buy a new one. They are cheap and pretty
flat. Hit the block side surface with some 320 grip
paper on a blocked surface to make sure it's flat.
As for the extra hole, more can help but keep in mind you are restricted on both paths AND you will not be able to open up the center hole in the mounting stud.
The kit I bought for 35 dollars had the gaskets, plate and new mounting stud.
Have fun.
Re: How to remove SB oil filter mounting plate? [Re: Dart 340] #145089
11/05/08 09:01 AM
11/05/08 09:01 AM
are you talking the 90 degree rt angle oil filter adapter or the plate for the straight mount to the block?
Re: How to remove SB oil filter mounting plate? #145090
11/05/08 11:19 AM
11/05/08 11:19 AM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
the straight mount. You don't need the right angle one to mount headers, do you?
Re: How to remove SB oil filter mounting plate? [Re: sharpie] #145091
11/05/08 12:57 PM
11/05/08 12:57 PM
depends on the headers.
Re: How to remove SB oil filter mounting plate? #145092
11/05/08 01:54 PM
11/05/08 01:54 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
what if I just used manifolds?
Re: How to remove SB oil filter mounting plate? [Re: sharpie] #145093
11/05/08 01:57 PM
11/05/08 01:57 PM
i dont believe you need the rt angle adapter for manifolds.
for 1 3/4 hooker super comps on an e body, you can use the shorty filter and it will fit straight to the block
Re: How to remove SB oil filter mounting plate? #145094
11/05/08 02:16 PM
11/05/08 02:16 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
My A body has headers and I don't need the righty either.
