Re: How to remove SB oil filter mounting plate?
[Re: sharpie]
#145076
11/03/08 02:03 PM
11/03/08 02:03 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
I have had good luck with a small chisel/screwdriver in the center hole. Drive it in at an angle between the plate and the block. Work around the inside in a circle. Don't jamb it in one side or you may bend the plate. Work it around and it will eventually break the seal on the outside edge. While you are at it add a few extra holes for the oil to flow through the plate like I have found on the HD engines. The weakest link for the everyday small block is the restrictive oil system IMHO.
[Re: Dart 340]
#145079
11/03/08 07:54 PM
11/03/08 07:54 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
You can buy a brand new kit for 35 dollars....
where? I can't find one either on Mancini or Summit!
[Re: sharpie]
#145081
11/04/08 03:14 PM
11/04/08 03:14 PM
Posts: 2,826 NY usa
540challenger
NY usa
I'd really like to find out!
i think you can still get them thru the dealer
[Re: sharpie]
#145082
11/04/08 03:26 PM
11/04/08 03:26 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
There is a guy in Minneapolis that I bought mine from. Give me 5 to find the link.
[Re: Dart 340]
#145085
11/04/08 03:53 PM
11/04/08 03:53 PM
P5249320 thats the Gskts to service the rt angle adapter which are the same as yoy neeed also there should be no adapter plate on the block with a 90adapter what are you trying to do here? the plate is available from mopar or was last time i checked you need that Pn too?.Rt angle oil fiter adapter Kits aint no 35.00 either they are 139.95 from Mancini.
[Re: scratchnfotraction]
#145087
11/04/08 04:39 PM
11/04/08 04:39 PM
Pn 2402103 14.55 from www.moparpartsamerica.com that the last freebie from me iam in the buisnees of selling pnS and locating.ad to soon be on here.
[Re: Dart 340]
#145089
11/05/08 09:01 AM
11/05/08 09:01 AM
are you talking the 90 degree rt angle oil filter adapter or the plate for the straight mount to the block?
#145090
11/05/08 11:19 AM
11/05/08 11:19 AM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
the straight mount. You don't need the right angle one to mount headers, do you?
[Re: sharpie]
#145091
11/05/08 12:57 PM
11/05/08 12:57 PM
depends on the headers.
#145092
11/05/08 01:54 PM
11/05/08 01:54 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
what if I just used manifolds?
[Re: sharpie]
#145093
11/05/08 01:57 PM
11/05/08 01:57 PM
i dont believe you need the rt angle adapter for manifolds.
for 1 3/4 hooker super comps on an e body, you can use the shorty filter and it will fit straight to the block
