Hemi with crossram intake,will it fit?
#1450570
06/10/13 02:00 PM
06/10/13 02:00 PM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
The crate Hemi I just traded for came with a crossram,If I bolt it on will it fit under the stock hood? How about under Six pack hood? If so think that hood would look good on a vert?
who is that guy?
Re: Hemi with crossram intake,will it fit?
[Re: Brian_wo]
#1450573
06/10/13 09:47 PM
06/10/13 09:47 PM
Posts: 2,252 Sebring, Florida
Mopar Grandpa
Sebring, Florida
Probably will not fit under the stock hood especially if you run air cleaners which you should. A six pack hood is probably good for height but you may have to clearance the hood for the rear carb, like I had to do on my 68 HEMI Barracuda. If you are looking for more h.p. I would use a single high rise and a 850. My engine made 75 more h.p. with the single intake but I was using the Indy Legend One alum. Heads which have larger intake ports than the runners on the cross ram. The cross ram choked the flow. Cross rams look cool but can hamper the h.p. potential. Now, is a six pack hood cool on a vert.??????? Everyone will have their own opinion, but your opinion is the only one that really counts. Maybe someone has tried it and can post a few pics. I will post a picture of my Barracuda and although you have a B body you will get an idea how high the carbs with air cleaners sit above the fender lines.
[Re: Mopar Grandpa]
#1450579
06/10/13 11:26 PM
06/10/13 11:26 PM
Brian_wo
Omaha Nebraska
The motor in the crate has a single 4 on it but I am getting a new MP crossram with it and really I am talking about it because of the cool factor when the hood is popped.
who is that guy?
[Re: Brian_wo]
#1450584
06/12/13 06:41 PM
06/12/13 06:41 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
I think it will fit terrible in your Runner. You should send that troublesome piece to me so you don't have to be bothered with that unsightly 426. I just recently put a 66 hemi in the coronet, you will not regret it. Even if you have to leave the hood off the car.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: Brian_wo]
#1450586
06/13/13 01:41 PM
06/13/13 01:41 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
I don't have the Cross Ram on mine, in line AFB's. I had to install the correct low style Hemi scoop for clearance but that was mostly because of my choice in Air Cleaners. Id run the 67 while you worked on the Roady! Who needs paint anyways. At least you'll be mobile and in a Hemi car no less.
