when ordering a helmet #1450169
06/09/13 09:00 PM
06/09/13 09:00 PM
Indiana
maxie Online boogie OP
maxie  Online Boogie OP
Indiana
I need to order a helmet and was wandering how well the system worked as far as measuring your head????
I seen on the jegs website it said to measure 1 inch bove your eyes to the largest diameter of your head.
Do they size about right doing that??????
Dont even know if the car is going to be fast enuff to need one
Do you prefer open or closed face and why???????
I hope the car runs deep into the 11's maybe high 10's. Who knows
Re: when ordering a helmet [Re: maxie] #1450170
06/09/13 09:10 PM
06/09/13 09:10 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Mine fit perfect measuring that way. I prefer open cause I can see a little better.
Re: when ordering a helmet [Re: maxie] #1450171
06/09/13 10:49 PM
06/09/13 10:49 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
An open is more comfortable, but a closed is a whole lot safer for the reason one wears a helmet in the first place.
Regarding size, IMO, just make sure the seller will allow you to exchange if the fit is not what you expect, and closed is a little more difficult to get right, or buy from a vendor at the track.
Re: when ordering a helmet [Re: jcc] #1450172
06/10/13 12:20 AM
06/10/13 12:20 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If at all possible, test-fit whatever helmet you're interested in; you want to be sure it can't rotate on your head, and that your ears are comfortable, and if you wear glasses, that you can get them on & off.
Personally, I prefer closed; keeps the old mug safe. You don't have to use the clear shield, and I don't in the car. I removed mine but put it back on for motorcycle use.
Re: when ordering a helmet [Re: maxie] #1450173
06/10/13 07:53 AM
06/10/13 07:53 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
I tried a G-force full face and hated it. I wear glasses and unless I tilted it way down it would lift the glasses up. Also if you have any low mounted gauges, you will either have to tilt your head down to see them or mount them higher w/ a full face.
I bought a Racequip open face and love it. It was better quality.
Yeah, it's got a smallblock.
Re: when ordering a helmet [Re: ] #1450175
06/10/13 08:13 PM
06/10/13 08:13 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I have used Bell open faced helmets since 1985. Always bought the same size with good results until this year. I bought a new Bell open faced helmet and it was so tight that I couldn't open my mouth with it on. Ended up getting the next size bigger. It fits better, but not good. and the strap is too long. Bell says that they increased the padding in the check area for some reason. May be wearing a differnt brand before long.
Brian Dunnigan
Re: when ordering a helmet [Re: maxie] #1450176
06/10/13 09:20 PM
06/10/13 09:20 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Is there a speed cut off for open face helmets?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
