Them's the brakes? #1449516
06/08/13 09:53 PM
06/08/13 09:53 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
This morning, I found a small-ish puddle of brake fluid next to the left rear wheel. I drove the car around, came home, and parked it. The drum brakes worked as good as always, and when I parked it, I wiped the backing plate down.
It's been a full day, and there is not a drip of fluid. I am assuming it came from that left rear brake cylinder, but now it is not leaking.
Any ideas?
*1969 383 4sp. Super Bee
*1966 Alfa Romeo Giulia Sprint GT
*1965 Porsche 356C
*2004 VW Passat Wagon
*2004 Mini Cooper S
*1967 Jaguar E-Type FHC
A mall cop is in our midst.
Re: Them's the brakes? [Re: new bee] #1449517
06/08/13 09:58 PM
06/08/13 09:58 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Thank the Mopar god.
Re: Them's the brakes? [Re: new bee] #1449518
06/08/13 10:23 PM
06/08/13 10:23 PM
Any ideas?
Pull the drums & ID which wheel cyl is leaking/replace it/bleed it out
Re: Them's the brakes? [Re: RapidRobert] #1449519
06/09/13 12:45 PM
06/09/13 12:45 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
Of course I can swap the part out, but I am more curious why it would leave a puddle (it did sit for a couple months), but now it all seems fine. If it no longer leaks, can I assume I don't need to replace the part?
*1965 Porsche 356C
*2004 Mini Cooper S
Re: Them's the brakes? [Re: new bee] #1449520
06/09/13 12:59 PM
06/09/13 12:59 PM
(1) not sure why but brake fluid/sealing behavior is erratic at best (2) No as it will again it's just a matter of when. Brake psi can reach 1500 or more & if gravity made it leak (even tho it was sitting) that doesn't speak well for the integrity of that particular wheel cyls' bore/seals
Re: Them's the brakes? [Re: new bee] #1449521
06/09/13 01:52 PM
06/09/13 01:52 PM
Kirkland, Washington
Pacnorthcuda Offline
Any ideas?
Couple things.
Is it possible that when you drove it before the puddle you applied the brakes harder than the test drive after clean up? It's entirely possible that the wheel cylinder is only leaking during heavy pressure. It needs to be rebuilt or replaced.
It's also possible (though maybe not likely) that is did leak after clean up but simply hasn't dripped on the floor yet.
Re: Them's the brakes? [Re: Pacnorthcuda] #1449522
06/09/13 02:07 PM
06/09/13 02:07 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
if i leaked once it,ll do it again,hopfully no in traffic.brake leaks DONT FIX THEM SELVES.
Re: Them's the brakes? [Re: new bee] #1449523
06/09/13 06:27 PM
06/09/13 06:27 PM
Probally one of them evil eastern OR conservatives came by, after seeing teh car sit so long, and put a little brake fluid on the ground so they could use that as a negotating tool to buy that old heap Maybe it was one of the rich Chinese car buyers put some on the ground with the same intent Maybe it was one of the NSA envoirmentalist activist that did it wanting to have it towed off and scrapped as being just to unsafe to be on the streets of Portland
Take the drum off and fix it, it ain't going to get any better
Re: Them's the brakes? [Re: new bee] #1449524
06/09/13 07:32 PM
06/09/13 07:32 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Any ideas?
Do you have a dog?.....if so maybe it wasn't brake fluid, might be pee!...DAMHIK
Re: Them's the brakes? [Re: DAYCLONA] #1449525
06/09/13 09:40 PM
06/09/13 09:40 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
I climbed under the car today, and the left rear cylinder is definitely leaking. Tomorrow, I will pull the wheel and drum off to see what's going on.
It's been almost 5 years since finishing the restoration, and I cannot recall if I used silicon or DOT 3 fluid. Is there a way to tell the difference?
*1965 Porsche 356C
*2004 Mini Cooper S
Re: Them's the brakes? [Re: new bee] #1449526
06/09/13 09:53 PM
06/09/13 09:53 PM
DOT 5 silicone is dyed a bluish purple color. Dot 3 or 4 is the standard clear/very light amber color.
Re: Them's the brakes? [Re: Pacnorthcuda] #1449527
06/09/13 10:03 PM
06/09/13 10:03 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
Cool - I am using DOT 3 or 4. I have read it's best to replace cylinders in pairs. True? Or, can I replace just the one? Sorry - I know this is maintenance 101, but it's been ages since I did this kind of stuff.
*1965 Porsche 356C
*2004 Mini Cooper S
Re: Them's the brakes? [Re: new bee] #1449528
06/09/13 10:11 PM
06/09/13 10:11 PM
They really should be done in pairs. If one is leaking, how long till the other goes, AND you want equal resistance/application of force from side to side.
Re: Them's the brakes? [Re: new bee] #1449529
06/09/13 10:11 PM
06/09/13 10:11 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
I would do both. For a few dollars and minutes it's one less thing to worry about. Your car is worth it.
Old, tired, and sometimes broke down. Me, not my car...
Re: Them's the brakes? [Re: Pacnorthcuda] #1449530
06/09/13 10:15 PM
06/09/13 10:15 PM
BDW Online content
BDW  Online Content
Interesting, never heard that before.
Re: Them's the brakes? [Re: BDW] #1449531
06/09/13 10:20 PM
06/09/13 10:20 PM
portland or
new bee Offline OP
Richard Cranium
new bee  Offline OP
Richard Cranium
portland or
Funny, they were brand new when I restored the car, and I have only put 4 thousand miles or so on the thing over the past few years. I didn't expect them to give up so easily. Looks like tomorrow I pretend to be a mechanic.
*1965 Porsche 356C
*2004 Mini Cooper S
Re: Them's the brakes? [Re: new bee] #1449532
06/09/13 10:31 PM
06/09/13 10:31 PM
IN
ahy Offline
ahy  Offline
IN
As a bonus you will get a rear brake fluid change. It wouldn't hurt to flush a couple pints of fluid through the front while you are at it and change the front fluid also.
