Them's the brakes?
#1449516
06/08/13 09:53 PM
06/08/13 09:53 PM
Posts: 7,066 portland or
new bee
Richard Cranium
Richard Cranium
portland or
This morning, I found a small-ish puddle of brake fluid next to the left rear wheel. I drove the car around, came home, and parked it. The drum brakes worked as good as always, and when I parked it, I wiped the backing plate down. It's been a full day, and there is not a drip of fluid. I am assuming it came from that left rear brake cylinder, but now it is not leaking. Any ideas?
*1969 383 4sp. Super Bee *1966 Alfa Romeo Giulia Sprint GT *1965 Porsche 356C *2004 VW Passat Wagon *2004 Mini Cooper S *1967 Jaguar E-Type FHC
A mall cop is in our midst.
Re: Them's the brakes?
[Re: RapidRobert]
#1449519
06/09/13 12:45 PM
06/09/13 12:45 PM
new bee
Richard Cranium
Richard Cranium
portland or
Of course I can swap the part out, but I am more curious why it would leave a puddle (it did sit for a couple months), but now it all seems fine. If it no longer leaks, can I assume I don't need to replace the part?
[Re: new bee]
#1449521
06/09/13 01:52 PM
06/09/13 01:52 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
Couple things. Is it possible that when you drove it before the puddle you applied the brakes harder than the test drive after clean up? It's entirely possible that the wheel cylinder is only leaking during heavy pressure. It needs to be rebuilt or replaced.
It's also possible (though maybe not likely) that is did leak after clean up but simply hasn't dripped on the floor yet.
[Re: new bee]
#1449523
06/09/13 06:27 PM
06/09/13 06:27 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
[Re: new bee]
#1449524
06/09/13 07:32 PM
06/09/13 07:32 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Do you have a dog?.....if so maybe it wasn't brake fluid, might be pee!...DAMHIK
[Re: DAYCLONA]
#1449525
06/09/13 09:40 PM
06/09/13 09:40 PM
new bee
Richard Cranium
Richard Cranium
portland or
I climbed under the car today, and the left rear cylinder is definitely leaking. Tomorrow, I will pull the wheel and drum off to see what's going on. It's been almost 5 years since finishing the restoration, and I cannot recall if I used silicon or DOT 3 fluid. Is there a way to tell the difference?
[Re: Pacnorthcuda]
#1449527
06/09/13 10:03 PM
06/09/13 10:03 PM
new bee
Richard Cranium
Richard Cranium
portland or
Cool - I am using DOT 3 or 4. I have read it's best to replace cylinders in pairs. True? Or, can I replace just the one? Sorry - I know this is maintenance 101, but it's been ages since I did this kind of stuff.
[Re: Pacnorthcuda]
#1449530
06/09/13 10:15 PM
06/09/13 10:15 PM
Posts: 4,727 Florida
BDW
They really should be done in pairs. If one is leaking, how long till the other goes, AND you want equal resistance/application of force from side to side.
Interesting, never heard that before.
[Re: BDW]
#1449531
06/09/13 10:20 PM
06/09/13 10:20 PM
new bee
Richard Cranium
Richard Cranium
portland or
Funny, they were brand new when I restored the car, and I have only put 4 thousand miles or so on the thing over the past few years. I didn't expect them to give up so easily. Looks like tomorrow I pretend to be a mechanic.
