70RR Trunk - cannot open - anyone drill lock out before #1449220
06/08/13 09:34 AM
06/08/13 09:34 AM
Upstate NY
454Baja Offline OP
454Baja  Offline OP
Upstate NY
I reused the old lock and buffed it up to look like new. After a dozen uses it no longer opens and I am stuck. There is no way I can squeeze my #$%^ thru the back seat frame and am residing to drilling out the lock. Anyone do this and will it work? i then need to buy a new one which I have not done yet.
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: 454Baja] #1449221
06/08/13 09:44 AM
06/08/13 09:44 AM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
No kids in the family or neighborhood that want an adventure? Easy enough to do if you can find someoone that fits - I hate drilling locks.
Old, tired, and sometimes broke down. Me, not my car...
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: 454Baja] #1449222
06/08/13 09:47 AM
06/08/13 09:47 AM
with the back seat out do you have a straight line of sight to the bolts for the catch? If so several long 3/8 extensions/a swivel socket & some electrical tape around the swivel to keep the socket in line might do the trick. Never drilled one but it's doable (patience & a sharp quality bit). EDIT Shoozy nailed it, either a kid or a dwarf or a midget whatever is available
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: Shoozy] #1449223
06/08/13 09:48 AM
06/08/13 09:48 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Never tried this on a B body, but I was able to make a long enough extension out of some flat stock to pop the lock from inside after I removed the rear seat in my old C body. I would also seriously consider getting a can of spray graphite lube for locks and try that before I drilled out my lock.
Don't be the exception.
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: Supercuda] #1449224
06/08/13 09:54 AM
06/08/13 09:54 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
One morning on the way to work, I locked my keys in the trunk of my 79 Aspen.
I popped out the rear seat and squeezed my 280lb fat azz thru the package shelf bracing and opened the truck by tripping the lock's linkage.
Made it to work with 2 minutes to spare!
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: B5 Bee] #1449225
06/08/13 12:45 PM
06/08/13 12:45 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Tape a screw driver to a broom stick and use your flash light. Look for the screw driver slot just about in the middle of the lock mechanism. Just give it a turn and she will pop right open.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: 70gtx440dana] #1449226
06/08/13 01:54 PM
06/08/13 01:54 PM
Ding Ding Ding I do believe we have a winna
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: RapidRobert] #1449227
06/08/13 02:24 PM
06/08/13 02:24 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Although I find a trunk monkey far more entertaining.
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: MPerry] #1449228
06/08/13 03:17 PM
06/08/13 03:17 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
You know, I would actually consider playing dumb and allowing some good hearted soul DO that,just for the pure entertainment value...
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: Sixgun] #1449229
06/08/13 04:16 PM
06/08/13 04:16 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Nowadays, it might be difficulty to ask some kid to go into the trunk of your car...be careful with that.
Screwdriver on the broomstick is the winner, might need to use a hose clamp to secure the screwdriver.
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: topside] #1449230
06/08/13 04:30 PM
06/08/13 04:30 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Ask the parents to send the kid over.
I can't afford this. mark
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: a12superbee] #1449231
06/09/13 08:35 AM
06/09/13 08:35 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Been there done that. Broom handle and a screw driver work great. Trust me
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: 70gtx440dana] #1449232
06/09/13 09:57 AM
06/09/13 09:57 AM
Southern by Choice
Shoozy Offline
Shoozy  Offline
Southern by Choice
Yep - perfect! (I always had a kid around to use)
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: Shoozy] #1449233
06/09/13 10:06 AM
06/09/13 10:06 AM
I would have wanted to see B5 Bee do it
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: RapidRobert] #1449234
06/09/13 10:26 AM
06/09/13 10:26 AM
Southern by Choice
Shoozy Offline
Shoozy  Offline
Southern by Choice
280 lbs? Can you say youtube? We do what we have to and he did and still got out to tell us about it.
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: 454Baja] #1449235
06/09/13 10:52 AM
06/09/13 10:52 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I drilled mine out. I put my key in and it just started turning. I have a fire break between the seat and trunk. I just drilled it out. Started w/ a small bit then a larger one until I could get a long skinny screw driver in. Still that way today. I didn't even remove the assembly.
Coming soon!!!!
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: Mr.Yuck] #1449236
06/09/13 10:53 AM
06/09/13 10:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
oh yeah and muuuuch easier than pulling the back seats out foooor sure.
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: Shoozy] #1449237
06/09/13 01:42 PM
06/09/13 01:42 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Just like a fish hook, went in easy, not much fun getting back out.
Re: 70RR Trunk - cannot open - anyone drill lock out before [Re: 19cuda73] #1449238
06/09/13 02:23 PM
06/09/13 02:23 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
I had to do that trick once.
who is that guy?
