Page 1 of 3 1 2 3
4 cams spec'ed for my 408 #1448862
06/07/13 02:41 PM
06/07/13 02:41 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Had 4 cams from 4 different places of business spec a new solid roller cam for my 408. lunati,hughes engines,bullet and brian from this forum.
408 specs,indy intake,indy heads 360-1 228cc in. port flow 239/154@.400 and 328/209@.700,11.3:1 comp,1 7/8 tti,727,5400 8" stall,4.10,28" tire,3300 race weight. heads have a lazy ex.port with 64% in. to ex. flow.
here are the cams spec'ed
259/263-107lsa
262/270-108
260/270-105
259/269-106
all cams carry my current lifts(.712/.688).
trying to match up a cam better to my comp. ratio and maybe improve my 60', so which cam would you pick? thanks
Re: 4 cams spec'ed for my 408 [Re: mopar dave] #1448863
06/07/13 02:51 PM
06/07/13 02:51 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
with a 4" stroke and a lite exhaust port, I would go with the 262/270-108, installed around 105, giving a bit later Intake closing of 56 for the stroke and a moderate amount of overlap at 50 to assist the exhaust.
Be a Rebel- Break the Laws of Physics!
Re: 4 cams spec'ed for my 408 [Re: mbogina] #1448864
06/07/13 03:09 PM
06/07/13 03:09 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Whichever one Tim told you,
.050 ain't the whole story, .200 up lifts especially on a roller
WIZE
In Car:
Re: 4 cams spec'ed for my 408 [Re: Streetwize] #1448865
06/07/13 03:44 PM
06/07/13 03:44 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
It would help if we knew car weight, conveter stall and rear end gears. The wrong combo could make it dog out of the hole or drop off before the lights
Re: 4 cams spec'ed for my 408 [Re: mopar dave] #1448866
06/07/13 04:10 PM
06/07/13 04:10 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Misc. questions / comments:
1. At what RPM do you want to shift it and how high are you expecting it will turn through the traps?
2. Don't get hung up on the intake / exhaust % #s.
3. I'm not a small-block person, but think the 259/263-107 would have have good mid-range and decent top-end. However, with your compression that one might be better on a 106 LSA, too.
4. Which one did Brian H. spec? I know he's got a good bit of small-block experience.
Re: 4 cams spec'ed for my 408 *DELETED* [Re: mopar dave] #1448867
06/07/13 04:33 PM
06/07/13 04:33 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Post deleted by pittsburghracer
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 4 cams spec'ed for my 408 [Re: pittsburghracer] #1448868
06/07/13 06:30 PM
06/07/13 06:30 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Which lobes did Tim spec? Bullet has a lot of different ramps for those durations, I think I know what he would have chosen cause my 414 is similar to yours and the cam I got now (old cam motion IROC grind) doesn't have enough lift for my new heads, so I'm thinking I might have Tim I regrind the Bullet I want for me on a smaller Base Circle
WIZE
In Car:
Re: 4 cams spec'ed for my 408 [Re: Streetwize] #1448869
06/07/13 07:17 PM
06/07/13 07:17 PM
SoCal
Brian Hafliger Offline
SoCal
Just remember the smaller you go on base circle, the less stable the lobe at rpm AND the less hardness you'll have left on a regrind...
JMO!
Brian
Brian Hafliger
Re: 4 cams spec'ed for my 408 [Re: Brian Hafliger] #1448870
06/07/13 07:18 PM
06/07/13 07:18 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Well remembered, Brian! Thanks!
WIZE
In Car:
Re: 4 cams spec'ed for my 408 [Re: Streetwize] #1448871
06/07/13 08:31 PM
06/07/13 08:31 PM
Mt Morris Michigan
Mt Morris Michigan
Sorry not at home right now. 3300# race weight 5400 vert 4.10 gear. Brian spec,Ed the 262/270-108. Tim was confident he could regrind but needs to see the cam.
Re: 4 cams spec'ed for my 408 [Re: Streetwize] #1448872
06/07/13 08:33 PM
06/07/13 08:33 PM
Mt Morris Michigan
Mt Morris Michigan
Tim spec'ed the 259/269-106 and this is the cam I'm liking.
Re: 4 cams spec'ed for my 408 [Re: pittsburghracer] #1448873
06/07/13 08:40 PM
06/07/13 08:40 PM
Mt Morris Michigan
Mt Morris Michigan
By air speed do you mean velocity?no cam company has ever ask for that before,but I think I can find that on Wallace racing and let ya know.
Re: 4 cams spec'ed for my 408 [Re: BradH] #1448874
06/07/13 08:43 PM
06/07/13 08:43 PM
Mt Morris Michigan
Mt Morris Michigan
I shift at 6800 and trap at 6800 with current cam.
Re: 4 cams spec'ed for my 408 [Re: Streetwize] #1448875
06/07/13 08:54 PM
06/07/13 08:54 PM
Mt Morris Michigan
Mt Morris Michigan
Tim told me my current cam was hurting me. It had their 2nd fastest lobe on the intake and a much slower lobe on the exhaust. What I'm trying to accomplish is increased cylinder pressure and better scavenging.
Re: 4 cams spec'ed for my 408 [Re: mopar dave] #1448876
06/07/13 08:59 PM
06/07/13 08:59 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Dave ,my sb is smaller ,394 ci, 10.9:1 my 360-2 heads flow 337@ 700 in.and 214 ex on W566DARTS [Brett] bench. They speced my cam it is 255/266 at .050 .
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 4 cams spec'ed for my 408 [Re: D-50] #1448877
06/08/13 12:41 AM
06/08/13 12:41 AM
Mt Morris Michigan
Mt Morris Michigan
your also 64% on your intake vs exhaust flow they gave you an 11* split. whats your lsa?
I like both the hughes engines spec and the bullet spec.
brian 262/270-108
lunati 259/263-107
hughes 260/270-105
bullet 259/269-106
Re: 4 cams spec'ed for my 408 [Re: mopar dave] #1448878
06/08/13 12:46 AM
06/08/13 12:46 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
For your car weight and gearing I would personally go with Brian's262/270, bit I would use a 106 lsa.
Keith
Re: 4 cams spec'ed for my 408 [Re: Dunnuck Racing] #1448879
06/08/13 12:49 AM
06/08/13 12:49 AM
Mt Morris Michigan
Mt Morris Michigan
ok,whats your reasoning on this? the hughes,bullet and brians spec are very close.
Re: 4 cams spec'ed for my 408 [Re: mopar dave] #1448880
06/08/13 01:00 AM
06/08/13 01:00 AM
central Pa.
71Pan Offline
71Pan  Offline
central Pa.
Bullet
Re: 4 cams spec'ed for my 408 [Re: mopar dave] #1448881
06/08/13 01:06 AM
06/08/13 01:06 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
brian 262/270-108
lunati 259/263-107
hughes 260/270-105
bullet 259/269-106
On the cam card it says Lobe Separation is 104 in./112 ex.
I have 1.65 T&D's and 704 lift.
Page 1 of 3 1 2 3
