4 cams spec'ed for my 408
#1448862
06/07/13 02:41 PM
06/07/13 02:41 PM
Posts: 8,041 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Had 4 cams from 4 different places of business spec a new solid roller cam for my 408. lunati,hughes engines,bullet and brian from this forum. 408 specs,indy intake,indy heads 360-1 228cc in. port flow 239/154@.400 and 328/209@.700,11.3:1 comp,1 7/8 tti,727,5400 8" stall,4.10,28" tire,3300 race weight. heads have a lazy ex.port with 64% in. to ex. flow. here are the cams spec'ed 259/263-107lsa 262/270-108 260/270-105 259/269-106 all cams carry my current lifts(.712/.688). trying to match up a cam better to my comp. ratio and maybe improve my 60', so which cam would you pick? thanks
Re: 4 cams spec'ed for my 408
[Re: mopar dave]
#1448863
06/07/13 02:51 PM
06/07/13 02:51 PM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
with a 4" stroke and a lite exhaust port, I would go with the 262/270-108, installed around 105, giving a bit later Intake closing of 56 for the stroke and a moderate amount of overlap at 50 to assist the exhaust.
Be a Rebel- Break the Laws of Physics!
[Re: mopar dave]
#1448866
06/07/13 04:10 PM
06/07/13 04:10 PM
BradH
Misc. questions / comments: 1. At what RPM do you want to shift it and how high are you expecting it will turn through the traps? 2. Don't get hung up on the intake / exhaust % #s. 3. I'm not a small-block person, but think the 259/263-107 would have have good mid-range and decent top-end. However, with your compression that one might be better on a 106 LSA, too. 4. Which one did Brian H. spec? I know he's got a good bit of small-block experience.
Re: 4 cams spec'ed for my 408 *DELETED*
[Re: mopar dave]
#1448867
06/07/13 04:33 PM
06/07/13 04:33 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Post deleted by pittsburghracer
[Re: mopar dave]
#1448876
06/07/13 08:59 PM
06/07/13 08:59 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Dave ,my sb is smaller ,394 ci, 10.9:1 my 360-2 heads flow 337@ 700 in.and 214 ex on W566DARTS [Brett] bench. They speced my cam it is 255/266 at .050 .
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
