Crankshaft Sockets #1448364
06/06/13 08:35 AM
06/06/13 08:35 AM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
Can someone help me order the right Tool here? I don't have access to my crank at the moment, and I'm kind of confused on there descriptions. Their descriptions are references 'inside diameter'... not sure if they meant O.D., or I'm clearly not understanding something. It is for a 318.
Cranshaft Sockets
'64 390 Valiant Signet Convertable (WIP...)
Re: Crankshaft Sockets [Re: capac] #1448365
06/06/13 10:31 AM
06/06/13 10:31 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
2011 Drag Pak Challenger
Re: Crankshaft Sockets [Re: capac] #1448366
06/06/13 11:12 AM
06/06/13 11:12 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
i think you need part number 4799 it is a nice piece, you can mount a degree wheel on it with the knurled nut. proform makes the same thing for about half the price but i think it is aluminum, number PRO-67493. i bought the comp cams chrysler degree kit 4937 and it came with the socket.
Re: Crankshaft Sockets [Re: capac] #1448367
06/06/13 01:21 PM
06/06/13 01:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
Tell us what you want the tool to do, a crankshaft socket to turn the crank bolt or a crank bolt type tool to hold a degree wheel ?
Re: Crankshaft Sockets [Re: capac] #1448368
06/06/13 05:05 PM
06/06/13 05:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
4799 is what I got
pro form a summit
http://www.summitracing.com/parts/pro-67493
mancini's
http://chucker54.stores.yahoo.net/cransoc2.html
you want one with the spin off degree wheel holder and set screws
Re: Crankshaft Sockets [Re: capac] #1448369
06/06/13 05:13 PM
06/06/13 05:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Crankshaft Sockets [Re: Cab_Burge] #1448370
06/07/13 11:17 AM
06/07/13 11:17 AM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
I need it to hold my degree wheel. The ability to turn the crank is just a bonus. I ended up ordering the 4799 model from summit. Hopefully it does what I need it to do, thanks!
