Wierd vacuum leak issue #1447816
06/05/13 02:40 AM
06/05/13 02:40 AM
moparmedic Offline OP
I have been dealing with a vacuum leak on a fresh 383. Thought the intake wasn't sealing properly and while looking for the leak with a can of carb cleaner found the leak was right around the exhaust crossover. When I spray carb cleaner directly in the opening in the head around the crossover, it will stall the engine. I will pull the head and check it later this week. Do the iron heads develop cracks in the heat riser/crossover area?
Seems like that may be whats going on...
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: Wierd vacuum leak issue [Re: moparmedic] #1447817
06/05/13 10:33 AM
06/05/13 10:33 AM
that is a very high heat(ed) area. That's why that horse shoe cavity needs to be kept uncovered & sometime even that ain't enough. Holler what you find.
Re: Wierd vacuum leak issue [Re: RapidRobert] #1447818
06/06/13 12:07 AM
06/06/13 12:07 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Another common problem is the cross-over area of the intake warping enough to not seal using just the tin valley pan...Lay a straight edge across the sealing surface of the intake to rule that out...
Re: Wierd vacuum leak issue [Re: screamindriver] #1447819
06/11/13 12:14 AM
06/11/13 12:14 AM
Took the head off it is at the machine shop. Didn't find anything obvious. They are going to pressure test it and see if they find anything.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: Wierd vacuum leak issue [Re: moparmedic] #1447820
06/11/13 12:23 AM
06/11/13 12:23 AM
What Screamin said, I'd be looking hard at the valley pan metal gasket, how it's sealing & possibly the intake itself (warped) but way less likely.
Re: Wierd vacuum leak issue [Re: RapidRobert] #1447821
06/14/13 12:55 AM
06/14/13 12:55 AM
Yeah, I did all of that. Everything looked good with a straight edge. I also reasealed the intake 3 times and used a different intake on the 3rd time. Also used the Fel Pro side gaskets and a new valley pan. I was down to getting the head checked and then I am out of ideas. Should know more by Monday.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
