Wierd vacuum leak issue
#1447816
06/05/13 02:40 AM
06/05/13 02:40 AM
Posts: 755 Oregon
moparmedic
I have been dealing with a vacuum leak on a fresh 383. Thought the intake wasn't sealing properly and while looking for the leak with a can of carb cleaner found the leak was right around the exhaust crossover. When I spray carb cleaner directly in the opening in the head around the crossover, it will stall the engine. I will pull the head and check it later this week. Do the iron heads develop cracks in the heat riser/crossover area? Seems like that may be whats going on...
1968 Coronet 1968 Charger 1966 A100 Pickup 1967 Barracuda 1970 Challenger 1972 Challenger 1973 Barracuda 2021 Ram 2500
Re: Wierd vacuum leak issue
[Re: moparmedic]
#1447817
06/05/13 10:33 AM
06/05/13 10:33 AM
RapidRobert
that is a very high heat(ed) area. That's why that horse shoe cavity needs to be kept uncovered & sometime even that ain't enough. Holler what you find.
[Re: screamindriver]
#1447819
06/11/13 12:14 AM
06/11/13 12:14 AM
Posts: 755 Oregon
moparmedic
Took the head off it is at the machine shop. Didn't find anything obvious. They are going to pressure test it and see if they find anything.
