removing water spots from primer #1447651
06/04/13 08:21 PM
06/04/13 08:21 PM
Palmyra, NY
63stabamatic Offline OP
Palmyra, NY
I have been very careful to wash my primered car in the shade but I screwed up and blasted some water on the hood in the sun while washing the front end. It waterspotted and nothing I've tried takes it out. It has two coats of black primer, I do like the look and I was eventually going to flat clear coat it. Short of repainting anyone have any ideas? Thanks.
Re: removing water spots from primer [Re: 63stabamatic] #1447652
06/04/13 08:23 PM
06/04/13 08:23 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Nope.
Re: removing water spots from primer [Re: Challenger 1] #1447653
06/04/13 08:33 PM
06/04/13 08:33 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
How bout wet sanding? (in the shade)
Re: removing water spots from primer [Re: mopowers] #1447654
06/04/13 09:01 PM
06/04/13 09:01 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Probally the impurities in the water thats done it. Most primers are not sealers and will absorbe water. Most likely your going to have to sand and reshoot it. Top coat it with flat black paint..
I am truckless..
Re: removing water spots from primer [Re: 63stabamatic] #1447655
06/04/13 09:42 PM
06/04/13 09:42 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Did you try washing it off with water?
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: removing water spots from primer [Re: 63stabamatic] #1447656
06/04/13 11:50 PM
06/04/13 11:50 PM
St. Paul, Mn.
Jim_S Offline
Jim_S  Offline
St. Paul, Mn.
vinegar and distilled water mixed 50/50 might neutralize the spots so they look like they are gone but, I would not trust putting any topcoat paint or clear over it.
69 Roadrunner 383 stock
Re: removing water spots from primer [Re: Silver70] #1447657
06/05/13 07:11 AM
06/05/13 07:11 AM
Palmyra, NY
Palmyra, NY
Yes, tried watering again mutipul times, (in the shade), all kinds of cleaners/waxes, vinegar even the new "Ratwax" that is supposed to take out water spots, straight primer is too porous a surface. Might give some of the newer dishwasher stuff that gets rid of spots on glass. Thanks for all the suggestions.
