88 chrysler fifth ave #1447565
06/04/13 03:12 PM
06/04/13 03:12 PM
st.louis mo
satjoe Offline OP
satjoe  Offline OP
st.louis mo
does anyine know the data plate codes for a 5th ave or a Dip? I found one in the boneyard that i think has a 8 1/4" rear that'll fit my 77 volare. I'm not quite sure that it has a suregrip in it. Any help here?
Re: 88 chrysler fifth ave [Re: satjoe] #1447566
06/04/13 04:03 PM
06/04/13 04:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Turn one axle. If the other one turns the same direction it's a sure grip. If the other wheel turns the opposite way it's an open one legger.
Re: 88 chrysler fifth ave [Re: satjoe] #1447567
06/04/13 04:34 PM
06/04/13 04:34 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
Other things to check for:
Oval or "stop sign" cover.
If stop sign, its a 10 bolt 7.25, not an 8.25 (also the axle tubes will neck down from 3" into the housing)
Count the turns of the driveshaft, too. The 8.25 could have 2.45, 2.76, or 2.94 gears (if stock). Could also be an f-body unit and have 3.23s.
1971 Challenger
Re: 88 chrysler fifth ave [Re: cudazappa] #1447568
06/04/13 07:56 PM
06/04/13 07:56 PM
Bowling Green, KY
cudaboy Online content
cudaboy  Online Content
Bowling Green, KY
Re: 88 chrysler fifth ave [Re: cudazappa] #1447569
06/04/13 10:45 PM
06/04/13 10:45 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
or look where the axle tubes go into the center casting. if they neck down to 2.5" it's a 7 1/4"....if they're 3" the whole way, it's an 8.25"
2017 Grand Cherokee Overland
