why 35 degrees max timing on a 440?
#1447423
06/04/13 12:42 PM
06/04/13 12:42 PM
Posts: 697 Central IL
70Sbird
Central IL
Just a question I was wondering about. MP, engine builders and the general consensus is that a 440 should be limited to 35 (+/-) degrees advance. I swapped my distributor last night due to a faulty pickup ,set the timing at 35 BTDC at 3,000 RPM and base timing is about 15 BTDC now at idle. I left the vac advance off, and the car runs good, no issues. I have a Rev-N-Nator ECU, They recommend not using the vacuum advance, In the latest tuning article in MA, Dr E-Booger says to run a vacuum advance. If I understand this correctly, the vacuum advance will add potentially 15 (+/-)degrees of advance giving me 50 degrees of advance at highway speed. how does that play into the recommendations of only a 35 degree max?
Re: why 35 degrees max timing on a 440?
[Re: 383man]
#1447431
07/06/13 09:53 AM
07/06/13 09:53 AM
Posts: 4,072 Mo.
racerx
Mo.
As was stated vacum advance only works at cruise and part throttle where vacum is high. The vacum advance does not work at wide open throttle because there is no vacum at wide open throttle. Thats why race cars dont use vacum advance since they are at full throttle most of the time. As for how much total mech advance it depends on the combo. I have seen anywhere from 32 to 40 on NA bigblock Mopar engines. Right now I run about 37 total on my 63. Many combo's will have to try it at different settings to get the best power without eng knock if it uses pump. Also aluminum vs iron heads makes a difference as does comp and many other things to determine full mech advance. Ron
So were do u guy generally run your timing on BB/aluminum ported heads(-1's)with 13.5 comp.?
[Re: 70Sbird]
#1447434
07/07/13 01:02 AM
07/07/13 01:02 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
My car runs it best 1/4's at 39 I start at 35 or 36 then keep adding till it's stops improving it kept improving but did not go past 39. My car is at 41 idling at 1500 but as soon as you add power it backs down to 39 (some slack in the system i think) so that's what it likes?? I have an old but good dyno program say it would like 40 41 up past 6000? but as said the variables on cam, combustion chamber, fuel, compression, torque converter, spark plug heat range elevation the list is a mile long but never had a 440 want less than 38 for total performance and my old RIP 542 ran it's best runs at 38 when everyone says 32 34 for a stroker?? now i have things that stablize my timing better like the dizz shaft collar so who knows what I would find now. yea have to try things.
[Re: Dodgem]
#1447435
07/07/13 05:05 PM
07/07/13 05:05 PM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
It all depends on the efficiency of the chamber, quench and quality of the fuel. If you have tight quench and a very efficient chamber, it won't need a lot of spark lead to get the mixture burnt properly. Case in point, my 360 has .036" quench and MP R/T heads. So, tight quench and a fair to decent chamber with a material that won't absorb heat too fast. I ran it at first, with 38 degrees total timing, locked out. In a pickup truck, 4wd, 4800 lbs and the aerodynamics of a brick. Never detonated. Didn't tinker with the timing at all. Set the initial, found out it'd start fine locked, so I locked it in and then hooked up the vacuum advance after all the adjustments were made. Fast forward. Bored with the truck and my '72 challenger had no engine. Yanked the 360 out of the truck and stuffed it in the car. Had occasion to chassis dyno it and, lo and behold, dropping timing to 35 degrees picked up power. Left it alone until I pulled it again to freshen it and ran it on the engine dyno prior to teardown. Long story short, this little engine made 388 hp with a low 31 degrees of total timing. Perf RPM intake and a comp, hyd roller, 216/224 @.050, 114 lobe separation, installed at 110. I didn't keep testing, but it may have made more power with even less timing. No longer work at that shop and the engine isn't complete yet so I have no further information on it. But, my point being, there is no magic number. Start low on the timing and turn it up until it slows down. Watch out for detonation and keep an eye on those plugs. Keep in mind a lean mixture needs more advance to burn fully (hence the need for vacuum advance once people started worrying about fuel economy).
[Re: dodgeboy11]
#1447436
07/07/13 05:14 PM
07/07/13 05:14 PM
Thumperdart
State of confusion
I hear ya but generally smallblocks like less lead from my experience..................
