why 35 degrees max timing on a 440? #1447423
06/04/13 12:42 PM
06/04/13 12:42 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Just a question I was wondering about.
MP, engine builders and the general consensus is that a 440 should be limited to 35 (+/-) degrees advance. I swapped my distributor last night due to a faulty pickup ,set the timing at 35 BTDC at 3,000 RPM and base timing is about 15 BTDC now at idle. I left the vac advance off, and the car runs good, no issues.
I have a Rev-N-Nator ECU, They recommend not using the vacuum advance, In the latest tuning article in MA, Dr E-Booger says to run a vacuum advance. If I understand this correctly, the vacuum advance will add potentially 15 (+/-)degrees of advance giving me 50 degrees of advance at highway speed. how does that play into the recommendations of only a 35 degree max?
Re: why 35 degrees max timing on a 440? [Re: 70Sbird] #1447424
06/04/13 12:45 PM
06/04/13 12:45 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
who says? I usually start at 36*. This one is at 38* all in at 2200rpm.
Coming soon!!!!
Re: why 35 degrees max timing on a 440? [Re: 70Sbird] #1447425
06/04/13 12:48 PM
06/04/13 12:48 PM
Kirkland, Washington
Pacnorthcuda Offline
The 35 max is mechanical advance, not vacuum. At wide open throttle you have no vacuum advance, if you did you would seriously detonate the motor.
Vacuum advance is for part throttle drive ability enhancement and mpgs, the motor CAN take 50 plus degrees of advance at part throttle, at full throttle it cannot.
Re: why 35 degrees max timing on a 440? [Re: Pacnorthcuda] #1447426
06/04/13 01:37 PM
06/04/13 01:37 PM
dogdays Offline
dogdays  Offline
Well, for the past 15 years or so the consensus best dyno numbers for stock heads show 38 degrees total at 3000 rpm.
How an electronic ignition "knows" there is a vacuum advance is beyond me. That's one reason I am suspicious of the RNN.
When you are not at wide open throttle there is less in the chamber and it takes longer to light it all off. That's why the vacuum advance is there. It is not at all unusual to have 55 degrees advance at light cruise.
R.
BTW, there are very few times where I have found E-booger to mis-speak.
Re: why 35 degrees max timing on a 440? [Re: dogdays] #1447427
06/04/13 02:07 PM
06/04/13 02:07 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I cant speak directly for Troy on the Rev N Nator but I have done a lot of testing on them. It does not " know there is vacuum advance working,but there is a little bit of an issue with most stock setups retarding timing due to the ecu not being able to maintain dwell. The Rev N Nator cures this and needs the timing to be reworked . Most guys are too stubborn and don't want to change all their settings so leaving the vacuum disconnected cures the part throttle ping.
I personally use the vacuum advance on my tow vehicle with this ignition ,but had to be careful with setting everything up correctly. I hope this clears up a little confusion
Keith
Re: why 35 degrees max timing on a 440? [Re: 70Sbird] #1447428
06/04/13 02:10 PM
06/04/13 02:10 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I've run and still run, my timing at 37*. Full out @ 1100 rpm. 25* in the distributor, so that gives me 12* initial timing. I haven't used a vacuum advance in 35 years. 'Works for me!
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: why 35 degrees max timing on a 440? [Re: dogdays] #1447429
06/04/13 02:12 PM
06/04/13 02:12 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
R.
Hence my question, the RNN thought is that as the vacuum advance moves the breaker plate around there is the potential for some "chatter" or movement. I honestly dont understand the "electronic flywheel" concept either, other than it is supposed to give you more smooth and stable timing. I do know that out of the box a distributor's vacuum advance will need to be tuned. I just didnt understand the thought behind NOT running a vacuum advance.
X2 about Rick, I have been following him since the days of the first One Lap car - The Blue space Duster! and he is seldom wrong!!!!
Re: why 35 degrees max timing on a 440? [Re: 70Sbird] #1447430
06/04/13 05:08 PM
06/04/13 05:08 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
As was stated vacum advance only works at cruise and part throttle where vacum is high. The vacum advance does not work at wide open throttle because there is no vacum at wide open throttle. Thats why race cars dont use vacum advance since they are at full throttle most of the time. As for how much total mech advance it depends on the combo. I have seen anywhere from 32 to 40 on NA bigblock Mopar engines. Right now I run about 37 total on my 63. Many combo's will have to try it at different settings to get the best power without eng knock if it uses pump. Also aluminum vs iron heads makes a difference as does comp and many other things to determine full mech advance. Ron
Re: why 35 degrees max timing on a 440? [Re: 383man] #1447431
07/06/13 09:53 AM
07/06/13 09:53 AM
Mo.
racerx Offline
racerx  Offline
Mo.
So were do u guy generally run your timing on BB/aluminum ported heads(-1's)with 13.5 comp.?
Re: why 35 degrees max timing on a 440? [Re: 70Sbird] #1447432
07/06/13 10:25 AM
07/06/13 10:25 AM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
413 is similar to 440 and I have 38° total on mine with no vacuum advance. I'm running slightly milled 452 heads.
Re: why 35 degrees max timing on a 440? [Re: 70Sbird] #1447433
07/06/13 10:25 AM
07/06/13 10:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
R.
Different heads and compression along with the fuel
need the timing at different points.. use the MINIMUM
timing that gives you the best conditions... if you
had a near perfect set up your timing would be about
33* with load... in a cruise condition you have very
little load and can have the vac pull more timing
in so its more efficient at that load... remember
that if you are just off idle cruising along you are
getting a SMALL amount of air and fuel into the cyl
so it needs more time to get the full burn in the cyl
to get the max out of it... its not compressed like
if you fired it at 33*... the 33* is whats needed
to get the full burn so the piston is just coming over the
top when the fuel has the max power to push the piston
down... its all about using what power is in the fuel
and when to ignite it to get the most out of it
EDIT
Fuel that isnt compressed burns very slowly vs fuel
that is compressed hence the added timing
Re: why 35 degrees max timing on a 440? [Re: 70Sbird] #1447434
07/07/13 01:02 AM
07/07/13 01:02 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
My car runs it best 1/4's at 39 I start at 35 or 36 then keep adding till it's stops improving it kept improving but did not go past 39. My car is at 41 idling at 1500 but as soon as you add power it backs down to 39 (some slack in the system i think) so that's what it likes??
I have an old but good dyno program say it would like 40 41 up past 6000?
but as said the variables on cam, combustion chamber, fuel, compression, torque converter, spark plug heat range elevation the list is a mile long but never had a 440 want less than 38 for total performance and my old RIP 542 ran it's best runs at 38 when everyone says 32 34 for a stroker?? now i have things that stablize my timing better like the dizz shaft collar so who knows what I would find now.
yea have to try things.
Re: why 35 degrees max timing on a 440? [Re: Dodgem] #1447435
07/07/13 05:05 PM
07/07/13 05:05 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
It all depends on the efficiency of the chamber, quench and quality of the fuel. If you have tight quench and a very efficient chamber, it won't need a lot of spark lead to get the mixture burnt properly. Case in point, my 360 has .036" quench and MP R/T heads. So, tight quench and a fair to decent chamber with a material that won't absorb heat too fast. I ran it at first, with 38 degrees total timing, locked out. In a pickup truck, 4wd, 4800 lbs and the aerodynamics of a brick. Never detonated. Didn't tinker with the timing at all. Set the initial, found out it'd start fine locked, so I locked it in and then hooked up the vacuum advance after all the adjustments were made. Fast forward. Bored with the truck and my '72 challenger had no engine. Yanked the 360 out of the truck and stuffed it in the car. Had occasion to chassis dyno it and, lo and behold, dropping timing to 35 degrees picked up power. Left it alone until I pulled it again to freshen it and ran it on the engine dyno prior to teardown. Long story short, this little engine made 388 hp with a low 31 degrees of total timing. Perf RPM intake and a comp, hyd roller, 216/224 @.050, 114 lobe separation, installed at 110. I didn't keep testing, but it may have made more power with even less timing. No longer work at that shop and the engine isn't complete yet so I have no further information on it. But, my point being, there is no magic number. Start low on the timing and turn it up until it slows down. Watch out for detonation and keep an eye on those plugs. Keep in mind a lean mixture needs more advance to burn fully (hence the need for vacuum advance once people started worrying about fuel economy).
Re: why 35 degrees max timing on a 440? [Re: dodgeboy11] #1447436
07/07/13 05:14 PM
07/07/13 05:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I hear ya but generally smallblocks like less lead from my experience..................
Re: why 35 degrees max timing on a 440? [Re: Thumperdart] #1447437
07/08/13 10:55 AM
07/08/13 10:55 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Course there is often a difference on what gives peak power on a dyno and what gives best 1/4 miles!
Re: why 35 degrees max timing on a 440? [Re: Dodgem] #1447438
07/08/13 01:58 PM
07/08/13 01:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
True.........a stocker racer a few here know was racing w/38 degrees timing(smallblock)or there about and thaught that backing it off would slow him down so he set it at around 32 degrees and actually went faster. Same guy raced w/a good amount of ballast in the trunk to "fool" the other racers and thinking he had em way covered, removed the weight and went slower............
Re: why 35 degrees max timing on a 440? [Re: Thumperdart] #1447439
07/08/13 05:29 PM
07/08/13 05:29 PM
Many things come to mind when I see a difference of opinion on this subject, a 440 is a 440 as long as your using similar parts. A stock open chamber head on a pump gas motor may like a tiny bit more timing than a similar motor with a close chamber iron head. Altitude will affect how much timing will work best also If you don't verify your timing marks on your balancer and timing tab on the front cover to actual TDC to start with, you will not know exactly how much timing you actually have BTW, not all timig lights will show the exact same thning, even on teh same motor with no changes in timing The last thing is to never say never when it comes to motors, test, test, and test some more Use the results that you like the best
