833 tailshaft bearing? #1447291
06/04/13 02:04 AM
06/04/13 02:04 AM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
I'm in the process taking my four speed apart, and need to remove the tailshaft bearing. What is the method or best way to go about doing this?
Thanks,
Zak
Re: 833 tailshaft bearing? [Re: Z_Z] #1447292
06/04/13 02:40 AM
06/04/13 02:40 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Do you mean the bushing right in front of the rear seal???
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: 833 tailshaft bearing? [Re: Sixgun] #1447293
06/04/13 06:54 AM
06/04/13 06:54 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I believe its K&D that make the tools to R&R the bushing. You can always take the tail houseing to a tranny shop. It doesnt take long to do it.
I am truckless..
Re: 833 tailshaft bearing? [Re: 340SHORTY] #1447294
06/04/13 08:16 AM
06/04/13 08:16 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
when I rebuilt mine a few years ago, I took it to a tranny shop. they did it for free. I watched the guy do it, that bushing was really in there.
Re: 833 tailshaft bearing? [Re: Z_Z] #1447295
06/04/13 12:29 PM
06/04/13 12:29 PM
Thanks,
Zak
Remove the snap ring on the shaft and then use a brass drift to knock it off the shaft
Re: 833 tailshaft bearing? [Re: Cab_Burge] #1447296
06/04/13 02:19 PM
06/04/13 02:19 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Alright cool I'll try that Cab, sounds good...amazing what I found after I thought I was just putting in new gaskets...lol thanks guys!
Re: 833 tailshaft bearing? [Re: Z_Z] #1447297
06/04/13 02:32 PM
06/04/13 02:32 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Before I had a press and a bearing splitter, I used to remove the snap ring and use a block of wood on the garage floor to protect the splined are of the tailshaft and let the main shaft assembly drop on to the wood a few times. The weight of the first gear and synchro assembly would pop the bearing off quite easily. Be sure to use heavy leather gloves or you WILL pinch your skin when the bearing does let go! No me gusta...
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 833 tailshaft bearing? [Re: 70440+6bbl] #1447298
06/04/13 04:49 PM
06/04/13 04:49 PM
I have used that method also, I was thinking of the 727 rear tailshaft bearing removal when posting that way The 4 speeds are different in many ways
Re: 833 tailshaft bearing? [Re: Cab_Burge] #1447299
06/04/13 08:44 PM
06/04/13 08:44 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Thanks guys! The block of wood trick worked awesome, now hope I can get everything switched over and put back together right...lol
Re: 833 tailshaft bearing? [Re: Z_Z] #1447300
06/05/13 01:01 PM
06/05/13 01:01 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
sorry after rereading I see you said bearing, not bushing.
Re: 833 tailshaft bearing? [Re: Z_Z] #1447301
06/05/13 01:46 PM
06/05/13 01:46 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
Hope we didnt keep you from it to long lastnight,get it back together?
Let me know if you want me to low ball that guy on the other tranny to get an idea of what he will do.
who is that guy?
Re: 833 tailshaft bearing? [Re: Brian_wo] #1447302
06/05/13 02:16 PM
06/05/13 02:16 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Not at all Brian,I was at a stopping point, just hope it works. .65 that's the next thing I gotta do, hope" I can put in press somehow..Thanks!
Re: 833 tailshaft bearing? [Re: Z_Z] #1447303
06/06/13 01:29 PM
06/06/13 01:29 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
the shop that did it for me had all these different size collars that fit on a slide hammer. it was a matter of finding the right size, dropping it down inside, screwing it into the slide hammer and pounding it out. good luck.
Re: 833 tailshaft bearing? [Re: Z_Z] #1447304
06/06/13 02:13 PM
06/06/13 02:13 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Heat the bearing in your oven and it will practically drop back on with a little help using a brass drift. If you can put the assembled main shaft in your fridge or freezer, it will drop in place with a warmed bearing with no tools at all.
Re: 833 tailshaft bearing? [Re: 70440+6bbl] #1447305
06/06/13 02:15 PM
06/06/13 02:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Set the oven at 250 and braze slowly ...
