Oil adapter to 90 degree Help! #1446464
06/02/13 08:28 PM
06/02/13 08:28 PM
Vt
Tofastforyou Offline OP
Vt
I have 1970 AAR that I'm restoring back to original, when I purchased the car it had header's with stock oil adapter. I have removed the headers and want put on a original 90 degree oil adapter back on with manifolds.
My problem once I take the oil filter off i cant get the bolt off the engine which holds the oil filter to the engine, the nut which is 1 inch, but the head of the bolt is to small and difficult to get hold to take off, any ideas?
Re: Oil adapter to 90 degree Help! [Re: Tofastforyou] #1446465
06/02/13 08:38 PM
06/02/13 08:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Do not use the nut. They are square drive inside, a 3/8" extension on a ratchet will fit.
(Unless it is 1/2" it has been quite a while....)
Re: Oil adapter to 90 degree Help! [Re: Tofastforyou] #1446466
06/02/13 09:13 PM
06/02/13 09:13 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Most of the nipples with the external hex are 1/2 in. internally and don't have the internal 3/8 sq. drive. I prefer them myself due to less restriction. As for getting them on and off, I have found that most sockets have a bit of a chamfer to them. This makes them slightly easier to slide onto a bolt head or nut, but creates a problem when dealing with thin hexs like yours. What I have found effective is to sacrifice a six point socket by grinding the opening down to the point where the chamfer no longer exists. This way you can usually get it to grip the hex. If all else fails an "easy out" or screw extracter should work. If you have to resort to this I would try to polish the scars out of the interior of the nipple before reusing it.
Re: Oil adapter to 90 degree Help! [Re: Tofastforyou] #1446467
06/02/13 10:03 PM
06/02/13 10:03 PM
Vt
Vt
so you are saying I run a 3/8 drive extension through the center of the bolt? I just tried this and the 3/8 extension is to big(Fat) to got through the bolt hole?
any other ideas? I don't need to reuse the bolt since the new 90 degree adapter does not require the use of this bolt.
Re: Oil adapter to 90 degree Help! [Re: Tofastforyou] #1446468
06/02/13 11:08 PM
06/02/13 11:08 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Grind the face off a socket or grind the 3/8 extension to fit
Re: Oil adapter to 90 degree Help! [Re: Tofastforyou] #1446469
06/02/13 11:33 PM
06/02/13 11:33 PM
scratchnfotraction Offline
last one i did i use a 1/2" drive airgun with a impact socket, couple fast bumps it came right off.
seems I had to grind a 3/8" drive 3" extention to fit the small square in the center of the nipple before also. I just used my 3/8" drive airgun and spun it right out.
before I ran my 90* adaptor I drilled it out to 1/2" and used a small ball shaped stone and sanding rolls to radius/blend the turns for better flow.
Re: Oil adapter to 90 degree Help! [Re: scratchnfotraction] #1446470
06/03/13 08:26 PM
06/03/13 08:26 PM
pennsylvania
poboyengineering Offline
pennsylvania
if you aren't going to use the nipple and plate again, use a chisel. be careful, and not too big a hammer. just enough to get it to break loose. that thing has been on there for 40 years now.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Oil adapter to 90 degree Help! [Re: poboyengineering] #1446471
06/03/13 09:03 PM
06/03/13 09:03 PM
I'd do Po'boys' trick & tap one of the holes in the flat plate CCW & see if turning the flat plate will grab the nut/insert & get it coming out. If not I'd as said grind a socket end chamfer flat & then keep the socket on the nut square as your trying to break it loose. EDIT first give the extension/socket a few good whacks straight on with a BFH. I checked one today & it has a smooth round bore inside. I coulda sworn I saw one way back that was square or hex inside
Re: Oil adapter to 90 degree Help! [Re: RapidRobert] #1446472
06/08/13 03:06 PM
06/08/13 03:06 PM
Vt
Vt
Thanks for everyone input, I finally got the bolt off using vise grips and impact!
Now I have another question, when I'm mounting the the 90 degree adapter do I use the round plate that i took off( see photo with 4 holes) between the adapter and the engine?
Thanks for you help on this matter :-)
Re: Oil adapter to 90 degree Help! [Re: Tofastforyou] #1446473
06/08/13 03:07 PM
06/08/13 03:07 PM
Vt
Vt
here a photo of my project!
Re: Oil adapter to 90 degree Help! [Re: Tofastforyou] #1446474
06/08/13 03:12 PM
06/08/13 03:12 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
NO! NOOOOOO....
Don't ask me how I know this.
use the large round gasket for the housing, and the small round gaskets,one for the inside around the hollow bolt, one for the outside under the hollow bolt head.When I was about 19, that thing gave me fits!
Hope this helps,
Bear
Re: Oil adapter to 90 degree Help! [Re: RapidRobert] #1446475
06/08/13 03:14 PM
06/08/13 03:14 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Rob, most if not all the ones I've seen HAVE the 3/8" socket drive hex in there.You are not getting senile....
Re: Oil adapter to 90 degree Help! [Re: Sixgun] #1446476
06/08/13 03:50 PM
06/08/13 03:50 PM
Vt
Vt
so i pitch the circle disk with 4 holes?
Re: Oil adapter to 90 degree Help! [Re: Tofastforyou] #1446477
06/08/13 03:57 PM
06/08/13 03:57 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
I used to worry about the "legs' on that gasket coming off and getting sucked into the oiling system, or just messing with the filter holes
(oil flows from the outside of the can thru the media,then thru the center hole back into the motor IIRC), so I would use the gaskets "loose".If all I had was the "spider" I would cut the legs off making a separate big outer, small inner.Always meant to ask Rapid or JohnRR or Andy about that, never did
(so little time, so many issues).Your call,might be fine as-is out of the box.
Bear
Re: Oil adapter to 90 degree Help! [Re: Tofastforyou] #1446478
06/08/13 10:36 PM
06/08/13 10:36 PM
Correct & make sure the block recessed circular depression is completely clean of gasket material. Felpro sells just the circular gasket seperately & reportedly it is a slight bit thicker than the one that comes in the MP 3 piece kit & therefore seals a bit better tho I've used both & no issues (with everything clean). You could do a little porting of the sharp edges in the 90 deg adapter if you're OK with hidden reworking & want to improve the oiling circuit a bit (depends on how hard you plan to run it) & more oiling mods are available.
Re: Oil adapter to 90 degree Help! [Re: RapidRobert] #1446479
06/09/13 11:40 AM
06/09/13 11:40 AM
Vt
Vt
putting together the two gaskets for the bolt, one cork one metal/rubber. can anyone verify which order they go on? i have Bolt, cork and gasket.
see photo
Re: Oil adapter to 90 degree Help! [Re: Tofastforyou] #1446480
06/09/13 11:51 AM
06/09/13 11:51 AM
slip the thin one on the bolt then insert the bolt/thin washer into the adapter then slip the thick cork on the bolt inside the concave face on the other end
Re: Oil adapter to 90 degree Help! [Re: RapidRobert] #1446481
06/09/13 12:08 PM
06/09/13 12:08 PM
Vt
Vt
I'm ADHD, so the adapter bolt, thin washer and then cork in that order?
so my photo is backwards. please verify!
Re: Oil adapter to 90 degree Help! [Re: Tofastforyou] #1446482
06/09/13 12:11 PM
06/09/13 12:11 PM
Vt
Vt
or does one the gaskets goes between the adapter and engine? Obviously the big one does, But I confused about the two small one's now?
Re: Oil adapter to 90 degree Help! [Re: Tofastforyou] #1446483
06/09/13 12:26 PM
06/09/13 12:26 PM
Me too. I suffer from ADD (all day drama) & IDGAF (I dont give a fxxx). Slip the thin one on the bolt & lodge it under the bolt head. Then insert the bolt (with the thin washer on it) into the adapter. Then on the other side add the thick cork washer to the threaded end of the bolt that protrudes from the concave face on the inside. Make sure the block circular recess is cleaned of all gasket material. Torque on the big bolt is 50 lbs (cleaned/lightly oiled threads) EDIT The thin one goes next to the bolt head (outside). The other thin one (thick cork) goes on the bolt on the (inside) AFTER you insert the bolt/thin washer into the adapter. Then the large circular gasket as you know goes in the block circular recess.
