Switching to a high volume oil pump #144532
11/01/08 10:59 PM
11/01/08 10:59 PM
Silverdale, WA
DEH9296 Offline OP
DEH9296  Offline OP
Silverdale, WA
I'm going to put in a Melling high volume oil pump (MH63HV)onto my '69 383. I know the bolts have to be longer, but is there any need to change to a longer distributor drive gear shaft??
Dave Hein deethein@yahoo.com 69 Road Runner 383 69 Charger 440 66 Satellite 361
Re: Switching to a high volume oil pump [Re: DEH9296] #144533
11/01/08 11:02 PM
11/01/08 11:02 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Nope, just need the longer bolts.
Darren
Re: Switching to a high volume oil pump [Re: DEH9296] #144534
11/01/08 11:02 PM
11/01/08 11:02 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Did your pump on the motor now fail?
Re: Switching to a high volume oil pump [Re: dOc !] #144535
11/01/08 11:04 PM
11/01/08 11:04 PM
Silverdale, WA
DEH9296 Offline OP
DEH9296  Offline OP
Silverdale, WA
Relief valve stuck open on me on a standard pump, I don't trust it to do it again
Re: Switching to a high volume oil pump [Re: DEH9296] #144536
11/02/08 06:17 PM
11/02/08 06:17 PM
Eau Claire, WI
ResQ911 Offline
super gas
ResQ911  Offline
super gas
Eau Claire, WI
I would suggest saving the spring from the standard Melling pump and swap it into the new HV Melling. I had some really high pressure after going to the HV pump (125+) Swapped the standard pressure spring and am now running around 80.
Re: Switching to a high volume oil pump [Re: ResQ911] #144537
11/02/08 09:01 PM
11/02/08 09:01 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
hope you have a deep /oversize pan.. the HV pumps can move a lot of oil in a hurry and leave the pan empty...
I am truckless..
