General update on blocks
#1444797
05/30/13 03:59 PM
05/30/13 03:59 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
Not sure why it happened as nobody explained it to me, but there's been another dry spell recently. Thankfully it has only been for a short while and availability is coming back.
note, "dealer inventory" only applies to participating chrysler dealerships, not speed shops.
Hope this helps somebody out.
-------------------------------------------- Hemi P5155072AB 4.25 finish Edit 6/6 15 in whse inventory
P5153862AB 4.500 finish Edit 6/6 2 in whse inventory
P5153942AB 4.24 rough 4 backorders, 4 in dealer inventory Edit 6-6, 3 in transit -------------------------------------- Wedge P5153860AB 4.50 finish Edit 6/5, 22 now available in whse inventory
P5153944AB Edit 6/6 4 in whse inventory, 2 in dealer inventory ------------------------------------- Small block P5153478AB 340 siamese 4.04 finish 2 in whse inventory
P5153743 340 siamese 4.175 rough 0 stock, 0 backorders, 0 dealer inventory
P5007552AB 340 replacement water 4.04 finish 21 in whse inventory
P5153579 5.2 magnum race siamese 3.91 finish 10 in whse inventory
P5153452 5.9 magnum race siamese 4.00 finish 1 backorder, 0 in transit, 0 dealer inventory
inquire for 48 degree apps
Rich H.
Esse Quam Videri
Re: General update on blocks
[Re: ZIPPY]
#1444799
05/30/13 05:24 PM
05/30/13 05:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Rich... any clue who is casting up the iron blocks these days... and I know Chrysler has a strange system of counting... but how can you have a back order if there is still product in the warehouse as in a few that you show.... thanks for the info.. I think I might look at picking up a 340 siamese
[Re: rickseeman]
#1444801
05/30/13 06:33 PM
05/30/13 06:33 PM
ZIPPY
S.E. Michigan
World never did actually make them, although I still call them world blocks along with alot of others. World farmed out the casting and machining from day one, and it's the same machine shop/packager and foundry as before.
sorry I could not disclose that in '07 but things were different back then.
The dealer inventory means the blocks are sitting at dealerships somewhere. Not at warehouses....if that helps explain what I meant.
Some of them are backordered because of the price the customer has agreed to...let's say for instance a guy who works at a dealer gets it at cost, if the dealer orders it from PDC inventory....that guy is not going to buy it from some other dealer in another state, pay more for the part because that other dealer won't give him a break on price, and pay for shipping on top of it. He will have the place he works at backorder it, and will wait for it so he pays less........that's how backorders happen on parts that are actually readily available, happens alot too. Mike's other question is answered in PM.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1444802
05/30/13 06:58 PM
05/30/13 06:58 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Thanks for the block info Zippy. Any word on the Dragpack hemi intakes? I heard there are changes.
"Just a Bracket car dressed up like a streetcar"
[Re: AlexP]
#1444805
05/31/13 11:20 AM
05/31/13 11:20 AM
ZIPPY
S.E. Michigan
Yeah it should not be much longer on 3942ab.
Personally if I had four of them I would sell them all at or above retail and immediately backorder another handful. Because it's plain to see they are going to show up, all of them including the wedge use a common casting. So it is only a matter of time before the 3942 variant is made, and when it happens there will be a bunch.
On 6.1 the original verdict was, when Saltillo changed over to Eagle/Apache they were all done with 6.1 blocks and they would never make them again. Then I heard a rumor they might come back with a reman part number and would be sold for a higher price. I won't believe that until I see something actually happen, though.
The drag pak intake is discontinued, assuming we're referring to P5155288? I do not necessarily agree with that decision but that's the info I can find on it.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1444807
06/01/13 11:34 AM
06/01/13 11:34 AM
Just-a-dart
Glendora Ca.
Thanks for the P5155288 info. I heard arrow is doing the next deal, will call them next week.
[Re: ZIPPY]
#1444809
06/01/13 08:32 PM
06/01/13 08:32 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
The drag pak intake is discontinued, assuming we're referring to P5155288? I do not necessarily agree with that decision but that's the info I can find on it. [/quote
Once again thanks! I know you would not be able to give info about a future model and engine but when this 6.2 Supercharged block comes out. Could you let us know. I hope they haven't pulled the plug on it. Any other stuff for the G3 that Fiat forgot to publish?
[Re: Dyno1]
#1444812
06/04/13 03:58 PM
06/04/13 03:58 PM
ZIPPY
S.E. Michigan
Are there any hemi blocks, minus lifter bores in the system? With the new NHRA hemi superstock rule luming for 2014, how many cast iron hemi heads are currently available? thanks, Dyno SS/AH 5583
There are 11 P5153943AB blocks available today, and there are 31 P4529898 bare iron heads to go with them.
Just to confirm and clarify that is the block with no lifter bores, and that's the head with no pushrod holes....
There are also, amazingly, 280 P4876855 complete stock replacement style iron heads in stock which seems like alot, alhough that would be the wrong choice for ss/ah....Just mentioning it because it's an iron hemi head, and the stock levels are very high right now.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1444813
06/05/13 11:13 AM
06/05/13 11:13 AM
ZIPPY
S.E. Michigan
There are now 22 blocks available for purchase on P5153860AB.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1444814
06/05/13 11:32 AM
06/05/13 11:32 AM
Posts: 528 Oak Grove, MN
lowflyingdart
Oak Grove, MN
Thank you for the update Zippy. Are there any 6.1 blocks and legal Drag Pak heads available?
"I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
[Re: lowflyingdart]
#1444815
06/05/13 12:40 PM
06/05/13 12:40 PM
ZIPPY
S.E. Michigan
You bet, LFD.
I have not seen any activity on 6.1 blocks or heads lately.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1444816
06/05/13 03:01 PM
06/05/13 03:01 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I don't get it. Wish a guy could snag some 6.1 stuff without springing for the aluminum block. If those blocks were about a grand cheaper there sure would be a lot more butt hurt LS lovers out there.
Mopar to the bone!!!
