Anyone have leaking mp valves have the aluminum ones #1444579
05/30/13 12:09 AM
05/30/13 12:09 AM
oklahoma
69suprbee Offline OP
oklahoma
They just don't stop leaking.tried several different of gaskets and sealers.i am going to try a set off Steel ones and see what they do.anybody have a similar prob?how it work ?
Re: Anyone have leaking mp valves have the aluminum ones [Re: 69suprbee] #1444580
05/30/13 12:54 AM
05/30/13 12:54 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
sb or bb?
sb usually got to be ground where the intake port goes into the head for the valve cover to seal.
Tony
70 AARCuda Vitamin C
Re: Anyone have leaking mp valves have the aluminum ones [Re: 70AARcuda] #1444581
05/30/13 03:22 AM
05/30/13 03:22 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I had them on my 71 RR and my 383 Duster race car and have the SB version on my 340 right now. Never had any troubles..
I am truckless..
Re: Anyone have leaking mp valves have the aluminum ones [Re: 69suprbee] #1444582
05/30/13 07:57 AM
05/30/13 07:57 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm not even sure what your asking about. I guess the guys above me are smarter than me?
Re: Anyone have leaking mp valves have the aluminum ones [Re: Challenger 1] #1444583
05/30/13 10:39 AM
05/30/13 10:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm with you , alumn. valves ???
Re: Anyone have leaking mp valves have the aluminum ones [Re: JohnRR] #1444584
05/30/13 10:48 AM
05/30/13 10:48 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Im guessing valve covers?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Anyone have leaking mp valves have the aluminum ones [Re: 69suprbee] #1444585
05/30/13 06:49 PM
05/30/13 06:49 PM
Cincinnati, Ohio
Cincinnati, Ohio
If your asking about SB aluminum valve covers?
Sometimes with some intake manifolds, I think mostly stock manifolds you have to clearance the lip some on the intake side of the cover.
Here a couple of crappy pictures of some old valve covers I used to run. I had to grind on them in 2 places to get them to clear the intake manifold. Actually I was just thinking they were like that(ground on) when I got them and I only did the baffle. They were used when I got them.
Here's how I handled my PCV valve baffle, I did this a long time ago, it worked well. Maybe not the best, but worked.
I think those little square things sticking out interfere with the valve covers?
