!@#%& clutch #1443360
05/28/13 09:22 AM
05/28/13 09:22 AM
Kent, Wa
340SHORTY Offline OP
Truck Nut
Truck Nut
Kent, Wa
Went to move the Dually so a friend can haul some stuff. Evidently somehow some moisture has gotten into the bellhouseing. The disc is evidently stuck to the flywheel. Tried starting it in gear but the parking lot was full of cars so we wernt able to move it very much. I sure wish my bad back and shot eyesight would allow me to work on it.. Im sure if the pressure plate was loosened up the disc will free up with a little persuasion..
I am truckless..
Re: !@#%& clutch [Re: 340SHORTY] #1443361
05/28/13 09:43 AM
05/28/13 09:43 AM
Lehigh Acres, Florida
rickstershemi Offline
do you have any free play in the clutch pedal...????
Rickster
Re: !@#%& clutch [Re: rickstershemi] #1443362
05/28/13 02:19 PM
05/28/13 02:19 PM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
The clutch pedal feels normal..All was well 3 months ago when it was last driven..
I am truckless..
Re: !@#%& clutch [Re: 340SHORTY] #1443363
05/28/13 06:17 PM
05/28/13 06:17 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I had that issue with that dump truck I bought. Idleing till it comes up to temp helped free it up. Still works ok.
Re: !@#%& clutch [Re: redraptor] #1443364
05/29/13 12:39 AM
05/29/13 12:39 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
had that happen once. had someone push the clutch pedal in, and gently worked a wide putty knife between the disc and the flywhell. worked fine after that.
1981 Dodge D150 360 auto
Re: !@#%& clutch [Re: basketcase] #1443365
06/12/13 02:50 AM
06/12/13 02:50 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Put it in gear, hold the clutch pedal down and crank while standing on the brake pedal. Should break free. Probably best to use 4th gear to make it harder to move the truck if it won't come unstuck.
