Re: wheel spacers
[Re: harborracer]
#1443289
05/28/13 01:09 AM
05/28/13 01:09 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I did it on the front on a front end I made... I had no problems.. it was a 1/4" spacer so the wheel would clear the caliper
Re: wheel spacers
[Re: jcc]
#1443291
05/28/13 01:27 PM
05/28/13 01:27 PM
Posts: 43,205 Bend,OR USA
Cab_Burge
Somewhat related, I know must severely shun wheels spacers, I wondered though, say on a hub with a dual pattern BC, would it be possible and beneficial to say bolt the spacer on with the unused wheel holes, making it much less like a conventional spacer and more like a thick hub? Any downside for this extra trouble?
I wouldn't want a spacer that didn't have full contact to the back side of the wheel onto the brake calipers or hub, no pressure points on the center like I think your wanting to do
Re: wheel spacers
[Re: jcc]
#1443293
05/28/13 02:44 PM
05/28/13 02:44 PM
MR_P_BODY
To better explain, say on a common Wilwood front alum hub, it is common to have 4.5 and 4.75" BC fine thread, what if one needed a 1/2" spacer, and added a fine thread FLAT headed socket screw countersunk to attach the spacer to the hub with the unused tapped holes? I don't see any pressure points in this solution. Not sure if its ideal, but has to better then a floating spacer.
From what your saying is you just want to attach the spacer BUT will still use the studs that are in the hub to hold the wheel on(not a stud mounted in the spacer).. if thats the case then its fine if the counter sunk screws/bolts dont stick up past the flat surface... I wouldnt use a stud mounted to the spacer
