Effect of wheel weight #1443256
05/27/13 11:26 PM
05/27/13 11:26 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Can someone tell me the gain of going to lighter wheel on the back vs ET ?
...........I mean what gain in time for every pound lighter
Dan
Re: Effect of wheel weight [Re: Wedgeman] #1443257
05/27/13 11:32 PM
05/27/13 11:32 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.bigblockdart.com/techpages/rotatingweight.shtml
dont know if this what you are looking for..but..
Tony
70 AARCuda Vitamin C
Re: Effect of wheel weight [Re: 70AARcuda] #1443258
05/27/13 11:42 PM
05/27/13 11:42 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
NOt sure I totally understand......wheels 15 pounds lighter in the back is worth .6 mph ?
Re: Effect of wheel weight [Re: Wedgeman] #1443259
06/01/13 09:23 AM
06/01/13 09:23 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I have heard that for 1 lb off the Wheel is like 80lbs off the body....
67 Barracuda
best 6.75 1/8 mile
Re: Effect of wheel weight [Re: Wedgeman] #1443260
06/01/13 09:30 AM
06/01/13 09:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
67 Barracuda
best 6.75 1/8 mile
No way.... a heavy wheel does take more power to
accelerate it BUT you also have to take into account
how far from center line of the axle the weight is...
if its a big 20" vs a 12" wheel
Re: Effect of wheel weight [Re: Wedgeman] #1443261
06/01/13 10:51 AM
06/01/13 10:51 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
67 Barracuda
best 6.75 1/8 mile
8 lbs is a closer estimate.
If you like drag racing, support your local track.
Re: Effect of wheel weight [Re: MR_P_BODY] #1443262
06/01/13 10:53 AM
06/01/13 10:53 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I read an opinion by Porsche Engineering years ago that decreasing the weight of a rim by 1 pound was equivalent to removing 1.4 pounds of static weight.
Re: Effect of wheel weight [Re: CHAPPER] #1443263
06/01/13 10:55 AM
06/01/13 10:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
67 Barracuda
best 6.75 1/8 mile
This is much more realistic ... but whats a 0 amongst
friends...LOL
Re: Effect of wheel weight [Re: MR_P_BODY] #1443264
06/01/13 01:31 PM
06/01/13 01:31 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
8 lbs even sounds like an over-estimate to me. think about it: that means if you save 5 lbs per rim, that's equal to 160 lbs off the car??? no way. I think the post above that references 1.4 as the factor is probably closer to accurate.
Re: Effect of wheel weight [Re: StealthWedge67] #1443265
06/01/13 03:09 PM
06/01/13 03:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That I understand but I was just saying that the
8# is more in line than 80#... the 1.4 might be real close..
I'm not positive on it
Re: Effect of wheel weight [Re: MR_P_BODY] #1443266
06/01/13 03:43 PM
06/01/13 03:43 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
The factory Dakota wheels are HEAVY.
I dropped 25# per front wheel/tire and 14# per rear wheel/tire.
That's 78# at axle speed.
I'm really hoping it should be good for 2 tenths.
The link from BigBlockDart indicates that each pound at axle speed is worth roughly 3 lbs vs carried weight.
If I had a racetrack that was open I could find out!
Re: Effect of wheel weight [Re: MR_P_BODY] #1443267
06/01/13 03:44 PM
06/01/13 03:44 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok....
I was questioning the effect of a very heavy wheel on the loss of ET because of the rotating mass
For example start with a 20lbs rim, make a few passes on a 3200 lbs car with 570hp...
Then given the same car with a lighter rotating mass at the rear with 11 lbs rims.........any change in ET ?????
Re: Effect of wheel weight [Re: Wedgeman] #1443268
06/01/13 06:06 PM
06/01/13 06:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok....
You should see some gain but its not gonna be much
and it might not even show if the weather isnt the same...
but lighter is always better
Re: Effect of wheel weight [Re: MR_P_BODY] #1443269
06/01/13 06:33 PM
06/01/13 06:33 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Interesting to put that to the test !
I'll keep you informed as I am changing for M/T Pro 5 rims soon.........
Re: Effect of wheel weight [Re: Wedgeman] #1443270
06/01/13 07:58 PM
06/01/13 07:58 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I've run heavy stock steel rims 15 x 10 vs 15 x 10 weld drag lite rims on the rear and 15 x 6 stock steel vs 15 x 3.5 weld drag lites on the front, can't remember the exact et difference but less than a tenth. and we're talking probably +50lbs difference
Re: Effect of wheel weight [Re: MR_P_BODY] #1443271
06/01/13 07:59 PM
06/01/13 07:59 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Re: Effect of wheel weight [Re: jcc] #1443272
06/01/13 08:52 PM
06/01/13 08:52 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
The number I always heard tossed around was losing 1lb of rotating weight is approx same as losing 3 lbs static weight.
The idea of testing wheel weight, would seem like a good and easy tech article for one of the car mags, just come up with a system to SECURELY bolt on some balanced wheel weight, and make runs.
Maybe fluid in the tires..??
Re: Effect of wheel weight [Re: jcc] #1443273
06/01/13 08:53 PM
06/01/13 08:53 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Stick each wheel option on a Spintron and measure it. Done
Due to moment of inertia, two wheels with the same weight can take different amount of torque to rotate and accelerate.
You could computer model/draft each wheel and put it into other software and give you the calculated difference. It's plug and chug right out of the book.
I'm afraid the difference is so small that variables in track testing may not give you a precise number of what is going on.
Re: Effect of wheel weight [Re: autoxcuda] #1443274
06/01/13 09:27 PM
06/01/13 09:27 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
This topic can be debated untill the cows or sheep come home.
What we were always taught that the difference in rotational weight that has to be put in motion or unsprung weight as opposed to carried weight or sprung weight is for every reduction of 1# of weight that has to put in rotation is equivilant to a reduction of 8# of carried weight.IE:A reduction of 20# of power driven rotating drivetrain is like removing 160# of carried weight.This is only a rule of thumb since fricton and other causes of parsitic drag play a part in the rotation of componants.IE: Brake pad or shoe drag.
Some good examples of lightweight componants are spools,axles,brake rotors,alum.hubs,driveshafts,wheels,tires and always the lightened engine rotating assemblies as well as trans assemblies.
Re: Effect of wheel weight [Re: B G Racing] #1443275
06/01/13 09:35 PM
06/01/13 09:35 PM
Sterling Heights, MI
John_T_Brown Offline
If it ain't broke fix it anyway!
