Re: Effect of wheel weight
[Re: Wedgeman]
#1443260
06/01/13 09:30 AM
06/01/13 09:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have heard that for 1 lb off the Wheel is like 80lbs off the body....
67 Barracuda best 6.75 1/8 mile
No way.... a heavy wheel does take more power to accelerate it BUT you also have to take into account how far from center line of the axle the weight is... if its a big 20" vs a 12" wheel
[Re: MR_P_BODY]
#1443262
06/01/13 10:53 AM
06/01/13 10:53 AM
Posts: 1,848 South Bend
John Brown
South Bend
I read an opinion by Porsche Engineering years ago that decreasing the weight of a rim by 1 pound was equivalent to removing 1.4 pounds of static weight.
[Re: CHAPPER]
#1443263
06/01/13 10:55 AM
06/01/13 10:55 AM
MR_P_BODY
8 lbs is a closer estimate.
This is much more realistic ... but whats a 0 amongst friends...LOL
[Re: MR_P_BODY]
#1443264
06/01/13 01:31 PM
06/01/13 01:31 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
8 lbs even sounds like an over-estimate to me. think about it: that means if you save 5 lbs per rim, that's equal to 160 lbs off the car??? no way. I think the post above that references 1.4 as the factor is probably closer to accurate.
[Re: StealthWedge67]
#1443265
06/01/13 03:09 PM
06/01/13 03:09 PM
MR_P_BODY
That I understand but I was just saying that the 8# is more in line than 80#... the 1.4 might be real close.. I'm not positive on it
[Re: MR_P_BODY]
#1443266
06/01/13 03:43 PM
06/01/13 03:43 PM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
The factory Dakota wheels are HEAVY. I dropped 25# per front wheel/tire and 14# per rear wheel/tire.
That's 78# at axle speed.
I'm really hoping it should be good for 2 tenths. The link from BigBlockDart indicates that each pound at axle speed is worth roughly 3 lbs vs carried weight. If I had a racetrack that was open I could find out!
[Re: Wedgeman]
#1443268
06/01/13 06:06 PM
06/01/13 06:06 PM
MR_P_BODY
Ok.... I was questioning the effect of a very heavy wheel on the loss of ET because of the rotating mass
For example start with a 20lbs rim, make a few passes on a 3200 lbs car with 570hp...
Then given the same car with a lighter rotating mass at the rear with 11 lbs rims.........any change in ET ?????
You should see some gain but its not gonna be much and it might not even show if the weather isnt the same... but lighter is always better
[Re: jcc]
#1443273
06/01/13 08:53 PM
06/01/13 08:53 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
Stick each wheel option on a Spintron and measure it. Done Due to moment of inertia, two wheels with the same weight can take different amount of torque to rotate and accelerate. You could computer model/draft each wheel and put it into other software and give you the calculated difference. It's plug and chug right out of the book. I'm afraid the difference is so small that variables in track testing may not give you a precise number of what is going on.
[Re: autoxcuda]
#1443274
06/01/13 09:27 PM
06/01/13 09:27 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
This topic can be debated untill the cows or sheep come home. What we were always taught that the difference in rotational weight that has to be put in motion or unsprung weight as opposed to carried weight or sprung weight is for every reduction of 1# of weight that has to put in rotation is equivilant to a reduction of 8# of carried weight.IE:A reduction of 20# of power driven rotating drivetrain is like removing 160# of carried weight.This is only a rule of thumb since fricton and other causes of parsitic drag play a part in the rotation of componants.IE: Brake pad or shoe drag. Some good examples of lightweight componants are spools,axles,brake rotors,alum.hubs,driveshafts,wheels,tires and always the lightened engine rotating assemblies as well as trans assemblies.
