Re: Car runs to rich at cruise rpm
[Re: rapom]
#1442834
05/27/13 11:12 AM
05/27/13 11:12 AM
Posts: 12,145 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
"I was thinking about knocking down the front jets about 5 sizes and increasing the back 5 sizes to make up for the loss."
Only for a test.
If you decide to keep the smaller primaries, drill the PVCRs out to get the mix back. I find that even their street carbs are a little fat and need smaller primary jets and bigger PVCRs. But the race carbs are much, much too fat at cruise and in the transitions for the street.
If this is a double pumper, they are way fat for the street and require several changes to get street friendly. It can be done, but does require some mods.
Master, again and still
[Re: rapom]
#1442841
05/27/13 02:08 PM
05/27/13 02:08 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Don't forget that all that extra fuel is washing down your cylinder walls and fouling your oil. Pull your dipstick, I bet your oil is black as diesel oil after only a little drive time. Not good! Without a wide band, a good reference book and a little experience the real fix will be a bit of a problem. You will need small drill bits for the PVCRs. Something in the .060 range +/-. If you over drill them, inserting wires can get you back close. But the balance between the mains and the PVCRs are just part of the issue. The transition slots are way fat as are all the metering block metering holes. This is a race carb and is metered as such. All these things can be changed/adjusted, but it is too much hassle for most people. Every carb I have messed with has needed at least tweaked to the particular engine. And some are not even remotely close. The WOT is usually not too bad. It is the idle, transitions and cruise that typically need the most attention. Some of the changes can be made seat of the pants. But cruise and some of that really needs to be done with a wide band. And a good Holley book. It takes time and experiments. The cruise should end up in the 14.7 range +/-. But most of the other adjustments are not so clear cut. I do not mean to make this sound difficult, but there is a lot going on with the carb from idle to cruise. And all the circuits overlap which makes targeting the issue that much more problematic. It is too small for your application, but believe it or not, the carb that consistently needs the least amount of mods to get really close to most engines I have messed with is the good old 3310 (750). From 340s to mild 400s, it is one of the best street and street/strip carbs I have seen.
[Re: rapom]
#1442842
05/27/13 02:27 PM
05/27/13 02:27 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
I have found that a lot of the Holley race carbs. are not good street carbs., especially at part throttle You can fix them by limiting the fuel feed on the idle and transition circuits by drilling them and tapping them for #6 brass set screws and then increasing or decreasing the size of the hole in the set screws. You reallly need a wide ban 02 sensor system on the car to be able to get the AFR dead on You can do that by the hit amd miss method, that will take a little longer I did a older Holley 1050 Domintaor 9375 non HP that way, I reduced the idle fuel feed hole size down from around .080 to .045 and then reduced the intermediate fel feed by similar amount percenatge wise, that took the AFR at very light part throttle cruise between 2000 and 2500 RPM from 11.0 to 11.6 to 13.5 to 13.8 AFR I should have reduced them even more and did some more fine tuning but I didn't You can also open up the idle, intermediate and high speed air bleeds on the top of thw carb. to lean the mixtures out also, lots of choices on fine tuning. You really need to make sure that the carb. does not go lean at wide open throttle also while fixng the other circuits on them, all of the circuits can and do affect the wide open throttle mixture some Good luck The main jets affect all of the mixture, I try and fix what is not what I like first, idle, transition, part throttle and then W.O.T.
[Re: RobX4406]
#1442844
05/27/13 03:24 PM
05/27/13 03:24 PM
Cab_Burge
What if the rich condition is prior to the mains activating?
Pin gauge or find out what the IFR's sized and go from there. If it's larger than ~.032, I'd find a way to get it sized around .032, reset idle mix, and try from there. The ultra should have adjustable bleeds for all the stuff you need to mess with to clean it up.
I wouldn't step down 5 in front and up 5 in rear to balance, you're asking for distribution issues doing that.
As I pointed out work on one circuit at a time, don't go changing the main jets expecting that to fix the idle or transition richness problems
[Re: justinp61]
#1442851
05/28/13 05:57 PM
05/28/13 05:57 PM
Posts: 1,883 Northern OH
rapom
Northern OH
Well for one thing I sure don't have to worry about them opening early and really richening things up. They were in the carb when I got it and I always read that you should have the power valve number 1/2 of the vacuum number. Thanks for the easy to understand writeup radar
