Need Traction #1442729
05/27/13 08:51 AM
05/27/13 08:51 AM
arizona
HP318 Offline OP
HP318  Offline OP
arizona
The only way to get traction now is to fill stock tank.I would like not to have the extra weight or have to get bigger tires.69 coronet 3500 lbs with me in it.318,low gear 904 4200 stall,4.10 DL,full cal trac system shocks on #5, lower hole,275/60/15 mt ET steet radials,poly lcr busings,moog offset uppers,oh tires 18 psi.,Tiers spin first 20 or 30 ft then grab.WT dist.53/47.Need low cost option,What do you think?
Re: Need Traction [Re: HP318] #1442730
05/27/13 09:06 AM
05/27/13 09:06 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Low cost? A set of used slicks...
If you can't handle the truth, you're living a lie.......
Re: Need Traction [Re: HP318] #1442731
05/27/13 10:58 AM
05/27/13 10:58 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m in the same boat.............took a bunch of wt. out and now hookin`s a problem plus even though my tires only had 10-12 passes on em they were 14+ months of street drivin and sittin on concrete old. Had I borrowed my buddys good slicks my et`s would of dropped for sure............live and learn. I`d try the suggested used slicks myself..............
Re: Need Traction [Re: HP318] #1442732
05/27/13 11:13 AM
05/27/13 11:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What have you tried for different settings... have
you tried moving the caltracs to the upper hole,..
you might need to hit the tire harder to plant it...
then you might need to soften the extension on the
shocks... how easy is it to move the front end and
how far does it move on the front... your gonna need
all you can get for front end lift with that engine
in a big heavy car thats nose heavy
EDIT
The best thing you can do is video the launch so you
KNOW what the facts are
Re: Need Traction [Re: MR_P_BODY] #1442733
05/27/13 11:18 AM
05/27/13 11:18 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What kind of numbers does the car run now ? You know et , 60 ft , mph and so on. Ron
Re: Need Traction [Re: 383man] #1442734
05/27/13 11:19 AM
05/27/13 11:19 AM
tboomer Offline
tboomer  Offline
And if you do put slicks on...Make sure you have a driveshaft loop...
Re: Need Traction [Re: MR_P_BODY] #1442735
05/27/13 12:12 PM
05/27/13 12:12 PM
arizona
HP318 Offline OP
HP318  Offline OP
arizona
MR P With a floorjack it comes up 4in.before the tires start to come off the floor. Its fairly easy to lift up at bumper, its got 90/10s,do you mean with shocks disconnected? no I haven't tried top hole,i thought that would make the tire spin worse.....my best has been [Email]13.03@103[/Email] 1.80 sixty.Bill
Re: Need Traction [Re: HP318] #1442736
05/27/13 03:38 PM
05/27/13 03:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You could use 1" or more of lift which would mean
another shock or use a shock extension... see if your
shock is limiting the travel... you might want to
cut the upper arm bumper down also
Re: Need Traction [Re: HP318] #1442737
05/27/13 03:48 PM
05/27/13 03:48 PM
I used the M/T ET Streets(13.50x30x15), ET Street Radials(315x60x15) and the M/T ET drag slicks(31x105.x15W), the ET Street work better on a bad track than the ET Street Radails did, the slicks worked the best BTW, the radails are faster than the ET Street bias plys on a good track, not so on the street or on a fair to bad track. I'm suprised that yours hooked with your foot at WOT Mine would go sideways unless I lifted or shifted into 2nd gear as soon as it started to spin, even then I needed to lift a little while shifting it into 2nd gear IHTHs
Re: Need Traction [Re: Cab_Burge] #1442738
05/27/13 04:14 PM
05/27/13 04:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cab... its a 318 in a heavy B-body thats nose heavy
Re: Need Traction [Re: MR_P_BODY] #1442739
05/27/13 07:00 PM
05/27/13 07:00 PM
arizona
HP318 Offline OP
HP318  Offline OP
arizona
Mr P upper arm bumpers are gone,I thank ride height is about 1 in. higher than stock.upper arms hit the frame.I will try upper hole,if that don't help maybe I wll get some 315/60/15s and put 4.56 gears in,its going though the traps at only 5300 any way,thanks for the replies..bill
Re: Need Traction [Re: HP318] #1442740
05/27/13 08:11 PM
05/27/13 08:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When you raise the body you reduce the travel... you
could use the gear.. a 318 isnt gonna make much torque
so the gear will help that also
Re: Need Traction [Re: MR_P_BODY] #1442741
05/27/13 08:41 PM
05/27/13 08:41 PM
arizona
HP318 Offline OP
HP318  Offline OP
arizona
currently I cross the line at 5300 with a 28in tire,i want to be at 6000 with a 30in tire,would 4.88 gear get me there? thanks.Is 53/47 considered nose heavy?
Re: Need Traction [Re: HP318] #1442742
05/27/13 09:24 PM
05/27/13 09:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Plug your numbers in one of these calculators...
http://www.wallaceracing.com/Calculators.htm
yes I would say 53/47 is nose heavy.. be glad its
not a BB or it would be worse
Re: Need Traction [Re: MR_P_BODY] #1442743
05/27/13 11:52 PM
05/27/13 11:52 PM
arizona
HP318 Offline OP
HP318  Offline OP
arizona
Mike....I have tried to use that calculator many times before and it never cam out right. been playing it just now realized you need to adjust for converter slip.
Re: Need Traction [Re: HP318] #1442744
05/28/13 12:04 AM
05/28/13 12:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah you have to figure conv slippage for the top
end rpm... as a rule I use 7% but if you know yours
just add that in
Re: Need Traction [Re: HP318] #1442745
05/28/13 08:43 AM
05/28/13 08:43 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I run the same width MT tire(275/50) and I couldn't make mine spin if I wanted to. My 60 is kind of soft at a best of 1.62 but its done that same 60 at 5 different tracks. It doesn't seem to care how much air pressure either, I have run from 14-18psi with no troubles. Your sure your front suspension moves freely?
68 Barracuda Formula S 340
Re: Need Traction [Re: Bad340fish] #1442746
05/28/13 10:50 AM
05/28/13 10:50 AM
arizona
HP318 Offline OP
HP318  Offline OP
arizona
BAD340...no im not,I will pull the shocks off and try to bounce it.Maybe tubular upper arms & strut rods should be the next change
Re: Need Traction [Re: HP318] #1442747
05/28/13 09:56 PM
05/28/13 09:56 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have the rms uppers and strut rods. It's easier to move the whole assembly through its travel than it is to move just the stock uca with poly bushings.
Re: Need Traction [Re: Bad340fish] #1442748
05/29/13 12:05 AM
05/29/13 12:05 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I agree with MR. P, go over the front suspension and see if you can get more lift out of it. Make sure nothing is binding up ( i hear poly bushings can tighten up travel). What torsion bars are in the car? A lighter bar will allow for more lift (more stored energy) You shouldn't have any problem getting it to hook on the 275/60's assuming you're on a prepped track.
My Dart runs 11.20's with a soft (1.60) 60' and hooks up on 275/60 ET street radials just fine with a stock suspension except for SS springs ( no 90/10 fronts or anything) It's 53/47 also.
