Tranny came apart, Don Brummer injured #1442181
05/26/13 11:05 AM
05/26/13 11:05 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Don's front drum blew at Eddyville and his foot was injured. I was told that there was news posted about his condition, but don't know where to find it. Anybody know? By the way, he had some kind of (carbon fiber-kevlar) shield, but it didn't completely do the job. When I looked at his tranny the front drum and drving shell were gone, and the trans case is missing around that area. Front clutch pack flopping around in there. There is a good sized dent in the floor with about a 1" hole in the floor. His gas pedal was bent like a tight "C" and had to take some of the brunt. In any case we wish him the best.
Re: Tranny came apart, Don Brummer injured [Re: SportF] #1442182
05/26/13 11:16 AM
05/26/13 11:16 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
wow hope all ends well 727
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Tranny came apart, Don Brummer injured [Re: SportF] #1442183
05/26/13 11:26 AM
05/26/13 11:26 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I hope he's ok...
now I'm thinking of adding a plate in the trans tunnel...I have the carbon fiber shield as well..my 727 is built with billet drum and all...but you never know..
Re: Tranny came apart, Don Brummer injured [Re: smokinwoody] #1442184
05/26/13 11:42 AM
05/26/13 11:42 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
ANOTHER testament to an alum or steel drum ...
Re: Tranny came apart, Don Brummer injured [Re: dOc !] #1442185
05/26/13 02:34 PM
05/26/13 02:34 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I had my race trans built a few years ago and passed on the front drum option. Never felt the need and the stuff was not available 30 years ago. The project is still under construction. I think I will call the builder and price out a steel front drum installed. This maybe my last "hurrah" and I won't be the only one driving it (Daughters & Granddaughters). I would rather spend the money on insurance than hospital bills. It would kill me to see one of them hurt because I was being cheap!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Tranny came apart, Don Brummer injured [Re: Polarapete] #1442186
05/26/13 05:25 PM
05/26/13 05:25 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Not the first time I've heard of the "approved" kevlar shield allowing debris to run right through it. Thing about the blanket is that it will absorb the energy. Unfortunately I'll be using the "approved" shield on my latest project as it's the best thing going for a stock floor pan racecar, but I'm also going to put my Lofgren blanket over that.
Re: Tranny came apart, Don Brummer injured [Re: J_BODY] #1442187
05/26/13 05:47 PM
05/26/13 05:47 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
well I have a blanket on my and it is double over, and I am gald. I blew one up broke the rear and free wheeled the trans the drum came apart. moved the floor boards, but nothing went though the blanket. I am sure I would of kill one them shields.
Re: Tranny came apart, Don Brummer injured [Re: VernMotor] #1442188
05/26/13 06:19 PM
05/26/13 06:19 PM
Taylor, Michigan
1BadLiLCharger Offline
Taylor, Michigan
...happened to a friend of mine two weeks ago, he's going with a 'Glide.
Re: Tranny came apart, Don Brummer injured [Re: VernMotor] #1442189
05/26/13 06:23 PM
05/26/13 06:23 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Dang Vern you sure broke that one.
Re: Tranny came apart, Don Brummer injured [Re: rt66jim] #1442190
05/26/13 06:39 PM
05/26/13 06:39 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I know my small block is a little slower with a powerglide but I will gladly sacrifice A little ET for safety and consistency. Two of my Friends exploded 727's.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Tranny came apart, Don Brummer injured [Re: pittsburghracer] #1442191
05/26/13 07:02 PM
05/26/13 07:02 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
This one is not from doing anything wrong. I left the line 20 ft out broke the rear end took all the teeth off the pinion. free wheel the trans and boom we had fire and parts every where.. No more Richmond gears for me. most of the time when we see this it is from someone doing something they should not. I race this car for 27 years. only had this happen one time.
Re: Tranny came apart, Don Brummer injured [Re: VernMotor] #1442192
05/26/13 07:25 PM
05/26/13 07:25 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Cousin had one blow. He broke a ring gear in the rear on launch. Had a blanket wrapped tight. It still bent his floorboard. He put another stock drum in the car and said the previous owner had more motor and most have hurt the gears. Titaz
There is nothing wrong with running a 727 or a 400 turbo. You just have to run a better drum that does not blow up if you break anything behind the transmission and hurt the sprag or just loose the sprag. Low band apply and good drums no problems. Just like you don't run 1,500 hp on stock rods. Just part of racing
Hope the foot heals.
Leon
Re: Tranny came apart, Don Brummer injured [Re: Leon441] #1442193
05/26/13 09:58 PM
05/26/13 09:58 PM
NYC
Dartari Offline
Dartari  Offline
NYC
What is it with some people they will spend the money on everything else on there racecar but wont spend it on a part that has a known weakness. It's a no brainer you make power equals billet drum and 16 element sprag there really is no excuse.
Re: Tranny came apart, Don Brummer injured [Re: Dartari] #1442194
05/26/13 11:14 PM
05/26/13 11:14 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
Don had a aluminum drum in the trans, last outing he sheared the pinion teeth on the 4.10 dana 60, broke the tailhousing and bent the main shaft, trans was repaired, gear replaced and sprag checked, 2nd run after was the explosion. He is still in the hospital, broke several bones in his right foot, they were going to decide today whether to amputate 2 toes or try to save them.
Be a Rebel- Break the Laws of Physics!
Re: Tranny came apart, Don Brummer injured [Re: mbogina] #1442195
05/26/13 11:40 PM
05/26/13 11:40 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Dang! hoping for the best... My first experience with this was similar to Verns. Buddy of mine had a Challenger street/strip car. Foot brake, 8.75 rear. We "assume" it broke the gear first, shocked the trans and rolled the sprag, and about 100 ft out all hell broke loose. Luckily he walked, or limped for about 6 months, away. This one opened up the tin floor like a cartoon sardine can...it actually wrapped around his ankle. Took out his gauges, stuck small pieces in the door panels. We were young and totally oblivious that this could even happen. Way before you could join a chat room and read of such things. Chuck Lofgren was at the track that day and we met him as he checked out the carnage. He explained what most likely happened and sure enough the rear gear was broke just like he said. From there on we put blanket on everything. As I stated earlier, I'm going to be putting on a "rules compliant" shield as the blanket itself is not 9's legal, but I'm still running my Lofgren blanket over that. Hope to hear more updates as to what happened... Stock floor pan? The "one piece rules compliant sheild" that fits stock floor pans well that most seem to use? again...hoping for the best for your friend.
Re: Tranny came apart, Don Brummer injured [Re: smokinwoody] #1442196
05/27/13 12:06 AM
05/27/13 12:06 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I hope he's ok...
That is what i did when i had my cage put in.
Re: Tranny came apart, Don Brummer injured [Re: smokinwoody] #1442197
05/27/13 09:23 AM
05/27/13 09:23 AM
NC
440Jim Offline
440Jim  Offline
NC
I hope he's ok...
I agree I hope he is OK.
You don't have to worry with the aftermarket front drum. But still everybody should inspect the sprag with any driveline failure (U-joint, ring gear, etc).
Re: Tranny came apart, Don Brummer injured [Re: 440Jim] #1442198
05/27/13 10:05 AM
05/27/13 10:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I hope he is OK .... BUT the 727 has been in THOUSANDS
of race cars over the years and in most cases they never
had/have a problem... you just dont do certain things...
when in low gear you DONT PEDAL IT... if you loose
traction SHIFT it... when you start getting on and
off the pedal when in low your ASKING to blow the sprag
and once you roll the sprag the drum will turn 2.2
times the engine RPM.. if your above 6200 rpm it CAN
blow the drum due to centrifugal force.... as Jim
said... if you break a drive line part CHECK the sprag
Re: Tranny came apart, Don Brummer injured [Re: mbogina] #1442199
05/27/13 10:13 AM
05/27/13 10:13 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I am curious as to why this alum drum failed.
Re: Tranny came apart, Don Brummer injured [Re: dartman366] #1442200
05/27/13 10:26 AM
05/27/13 10:26 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I thought they would stand 20,000 rpms.
