Re: Tranny came apart, Don Brummer injured
[Re: SportF]
#1442182
05/26/13 11:16 AM
05/26/13 11:16 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
wow hope all ends well 727
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: smokinwoody]
#1442184
05/26/13 11:42 AM
05/26/13 11:42 AM
Posts: 30,465 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
..my 727 is built with billet drum and all...but you never know..
ANOTHER testament to an alum or steel drum ...
[Re: dOc !]
#1442185
05/26/13 02:34 PM
05/26/13 02:34 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I had my race trans built a few years ago and passed on the front drum option. Never felt the need and the stuff was not available 30 years ago. The project is still under construction. I think I will call the builder and price out a steel front drum installed. This maybe my last "hurrah" and I won't be the only one driving it (Daughters & Granddaughters). I would rather spend the money on insurance than hospital bills. It would kill me to see one of them hurt because I was being cheap!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: VernMotor]
#1442189
05/26/13 06:23 PM
05/26/13 06:23 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
well I have a blanket on my and it is double over, and I am gald. I blew one up broke the rear and free wheeled the trans the drum came apart. moved the floor boards, but nothing went though the blanket. I am sure I would of kill one them shields.
Dang Vern you sure broke that one.
[Re: rt66jim]
#1442190
05/26/13 06:39 PM
05/26/13 06:39 PM
Posts: 20,194 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I know my small block is a little slower with a powerglide but I will gladly sacrifice A little ET for safety and consistency. Two of my Friends exploded 727's.
[Re: VernMotor]
#1442192
05/26/13 07:25 PM
05/26/13 07:25 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Cousin had one blow. He broke a ring gear in the rear on launch. Had a blanket wrapped tight. It still bent his floorboard. He put another stock drum in the car and said the previous owner had more motor and most have hurt the gears. Titaz
There is nothing wrong with running a 727 or a 400 turbo. You just have to run a better drum that does not blow up if you break anything behind the transmission and hurt the sprag or just loose the sprag. Low band apply and good drums no problems. Just like you don't run 1,500 hp on stock rods. Just part of racing
Hope the foot heals.
Leon
[Re: Dartari]
#1442194
05/26/13 11:14 PM
05/26/13 11:14 PM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
Don had a aluminum drum in the trans, last outing he sheared the pinion teeth on the 4.10 dana 60, broke the tailhousing and bent the main shaft, trans was repaired, gear replaced and sprag checked, 2nd run after was the explosion. He is still in the hospital, broke several bones in his right foot, they were going to decide today whether to amputate 2 toes or try to save them.
Be a Rebel- Break the Laws of Physics!
[Re: mbogina]
#1442195
05/26/13 11:40 PM
05/26/13 11:40 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Dang! hoping for the best... My first experience with this was similar to Verns. Buddy of mine had a Challenger street/strip car. Foot brake, 8.75 rear. We "assume" it broke the gear first, shocked the trans and rolled the sprag, and about 100 ft out all hell broke loose. Luckily he walked, or limped for about 6 months, away. This one opened up the tin floor like a cartoon sardine can...it actually wrapped around his ankle. Took out his gauges, stuck small pieces in the door panels. We were young and totally oblivious that this could even happen. Way before you could join a chat room and read of such things. Chuck Lofgren was at the track that day and we met him as he checked out the carnage. He explained what most likely happened and sure enough the rear gear was broke just like he said. From there on we put blanket on everything. As I stated earlier, I'm going to be putting on a "rules compliant" shield as the blanket itself is not 9's legal, but I'm still running my Lofgren blanket over that. Hope to hear more updates as to what happened... Stock floor pan? The "one piece rules compliant sheild" that fits stock floor pans well that most seem to use? again...hoping for the best for your friend.
[Re: smokinwoody]
#1442196
05/27/13 12:06 AM
05/27/13 12:06 AM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
I hope he's ok...
now I'm thinking of adding a plate in the trans tunnel...I have the carbon fiber shield as well..my 727 is built with billet drum and all...but you never know..
That is what i did when i had my cage put in.
[Re: smokinwoody]
#1442197
05/27/13 09:23 AM
05/27/13 09:23 AM
Posts: 16,928 NC
440Jim
NC
I hope he's ok...
I agree I hope he is OK. You don't have to worry with the aftermarket front drum. But still everybody should inspect the sprag with any driveline failure (U-joint, ring gear, etc).
[Re: 440Jim]
#1442198
05/27/13 10:05 AM
05/27/13 10:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I hope he is OK .... BUT the 727 has been in THOUSANDS of race cars over the years and in most cases they never had/have a problem... you just dont do certain things... when in low gear you DONT PEDAL IT... if you loose traction SHIFT it... when you start getting on and off the pedal when in low your ASKING to blow the sprag and once you roll the sprag the drum will turn 2.2 times the engine RPM.. if your above 6200 rpm it CAN blow the drum due to centrifugal force.... as Jim said... if you break a drive line part CHECK the sprag
[Re: mbogina]
#1442199
05/27/13 10:13 AM
05/27/13 10:13 AM
dartman366
Mt. Vernon, Ohio
I am curious as to why this alum drum failed.
[Re: dartman366]
#1442200
05/27/13 10:26 AM
05/27/13 10:26 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I thought they would stand 20,000 rpms.
