Re: need help with mopar part?
[Re: moparsquid]
#1441814
05/25/13 06:36 PM
05/25/13 06:36 PM
RapidRobert
Can you take a close up pic of both ends
[Re: moparsquid]
#1441816
05/25/13 07:26 PM
05/25/13 07:26 PM
RapidRobert
Could be tack or speedo & the end on the right goes into the speedo head. Someone will have to recognize & run the # to find the apps it was made for & the ends are pretty much universal & it depends if the overall length will work for your app if you are wanting to use it for yourself. I just went thru this with my 65 dart with a later 904 & a Pioneer cable for a 67 dart fit on both ends but was a fair amount longer so it doesn't follow the firewall as tight as the original did but all good & I have a working speedo now. EDIT I reread your post & it's only the inner cable & no outer sheath? Yes you'll have to find the exact app by measuring the length if the # does not help someone to look it up. I tried (twice) to crimp an add on square tip to the end on the left side after shortening a universal inner cable to the right length to fit my outer sheath after my inner cable shredded as after cutting you need to restore the square tip to fit the trans & it bound up & shredded again so I just got the above Pioneer cable/sheath & I'm done
[Re: moparsquid]
#1441818
05/25/13 08:12 PM
05/25/13 08:12 PM
RapidRobert
There was 2 lengths listed for my app a 60"xx one and a 80"xx one & I got the shorter one & it was still ~8" longer than my OE unit. The speedo shop in Lincoln is closed or I would have had them do it (to restore that square tip end on a universal long cable) as it was a wasted effort (twice) on my part. Yeah I would measure the length & eBay it & either someone will need that exact length & snatch it up or someone that knows how to shorten/recrimp the end & needs one will buy it
