need help with mopar part? #1441811
05/25/13 05:30 PM
05/25/13 05:30 PM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
I recieved this cable some time ago ,I got it off of E-bay and was told it was a tach cable, but looks more loke a speedo. part description reads 1 piece #3635. 671 shaft WPP 11/72 any help is thanked im gonna list this on e-bay when I find out what it goes to. thanks
Re: need help with mopar part? [Re: moparsquid] #1441812
05/25/13 05:35 PM
05/25/13 05:35 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
if i had x-ray vision i could probaly help ya out.
Re: need help with mopar part? [Re: bonefish] #1441813
05/25/13 06:03 PM
05/25/13 06:03 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
sorry didnt realize that dicription was not enough,thanks
Re: need help with mopar part? [Re: moparsquid] #1441814
05/25/13 06:36 PM
05/25/13 06:36 PM
Can you take a close up pic of both ends
Re: need help with mopar part? [Re: RapidRobert] #1441815
05/25/13 07:16 PM
05/25/13 07:16 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
here it is like for a tach or speedo but what make and modle?
Re: need help with mopar part? [Re: moparsquid] #1441816
05/25/13 07:26 PM
05/25/13 07:26 PM
Could be tack or speedo & the end on the right goes into the speedo head. Someone will have to recognize & run the # to find the apps it was made for & the ends are pretty much universal & it depends if the overall length will work for your app if you are wanting to use it for yourself. I just went thru this with my 65 dart with a later 904 & a Pioneer cable for a 67 dart fit on both ends but was a fair amount longer so it doesn't follow the firewall as tight as the original did but all good & I have a working speedo now. EDIT I reread your post & it's only the inner cable & no outer sheath? Yes you'll have to find the exact app by measuring the length if the # does not help someone to look it up. I tried (twice) to crimp an add on square tip to the end on the left side after shortening a universal inner cable to the right length to fit my outer sheath after my inner cable shredded as after cutting you need to restore the square tip to fit the trans & it bound up & shredded again so I just got the above Pioneer cable/sheath & I'm done
Re: need help with mopar part? [Re: RapidRobert] #1441817
05/25/13 07:58 PM
05/25/13 07:58 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
the length is 140" quite long maybe for a big truck?
Re: need help with mopar part? [Re: moparsquid] #1441818
05/25/13 08:12 PM
05/25/13 08:12 PM
There was 2 lengths listed for my app a 60"xx one and a 80"xx one & I got the shorter one & it was still ~8" longer than my OE unit. The speedo shop in Lincoln is closed or I would have had them do it (to restore that square tip end on a universal long cable) as it was a wasted effort (twice) on my part. Yeah I would measure the length & eBay it & either someone will need that exact length & snatch it up or someone that knows how to shorten/recrimp the end & needs one will buy it
Re: need help with mopar part? [Re: moparsquid] #1441819
05/26/13 09:00 AM
05/26/13 09:00 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
That number shows up as a cable on an inventory list at this site found with a google search. http://www.valleytruckcenter.net/inventory.htm Call them and find out if they know what it fits. 1-800-492-0100
Re: need help with mopar part? [Re: GomangoCuda] #1441820
05/26/13 10:05 AM
05/26/13 10:05 AM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks ill give them a call
Re: need help with mopar part? [Re: moparsquid] #1441821
05/26/13 09:56 PM
05/26/13 09:56 PM
Jacksonville, FL
burnt_o_matic Offline
Jacksonville, FL
It's a Tachograph Cable Drive Shaft, 140" Long, .150" Dia. Core, for a 74-77 Medium-Heavy truck, Model 1000, according to my parts book.
What's a tachograph?
Re: need help with mopar part? [Re: burnt_o_matic] #1441822
05/27/13 12:16 AM
05/27/13 12:16 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
a tachograph was a device installed on commercial vehicles and fleet vehicles to monitor the speed that the drive maintained and at what time they maintained that speed.
http://intranet.kingsmac.co.uk/depts/phy...0Tachograph.htm
Re: need help with mopar part? [Re: macmic87] #1441823
05/27/13 01:00 AM
05/27/13 01:00 AM
Spring Valley ,Ca.
Spring Valley ,Ca.
you know it actually says that ,someone wrote it in inkon the cardboard, (cable 73 74 tachograph dt1000 140" i figured it was scribling is there any demand for this ,? probably not thanks for the imfo.
