Fuel gage fitting help #1441050
05/23/13 08:35 PM
05/23/13 08:35 PM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
I need a 1/2" male pipe X -8an male fuel gage fitting, with 1/8" female pipe for the gage. Lot's of 3/8" male pipe, but haven't found 1/2". Anyone?
Re: Fuel gage fitting help [Re: Leigh] #1441051
05/24/13 01:46 AM
05/24/13 01:46 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I'll get out in the shop and root around tomorrow....it sounds familiar , but no guarantees.
Re: Fuel gage fitting help [Re: Leigh] #1441052
05/24/13 09:06 AM
05/24/13 09:06 AM
Ohio
3404 Offline
3404  Offline
Ohio
Thats a odd step combination. You may have to bush the 1/2NPT down to 3/8" or get a flare reducer to take the -10 to -8
Re: Fuel gage fitting help [Re: Leigh] #1441053
05/24/13 09:21 AM
05/24/13 09:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I know you can get the 1/2 X 8AN but you might have
to drill and tap the 1/8 pipe
Re: Fuel gage fitting help [Re: Leigh] #1441054
05/24/13 10:46 AM
05/24/13 10:46 AM
gregsdart Offline
gregsdart  Offline
Leigh you could stop by and see what I have. I have a lot of odd stuff, plus taps. Are you asking for a fitting that is 1/2 pipe, 8an on the other end, and 1/8 pipe for the gauge all on one fitting?
Re: Fuel gage fitting help [Re: gregsdart] #1441055
05/24/13 11:01 AM
05/24/13 11:01 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
1/2 to 3/8 pipe is a common reduser try any good hardware or home depo.
Re: Fuel gage fitting help [Re: gregsdart] #1441056
05/24/13 11:14 AM
05/24/13 11:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats what I'm thinking he wants... 1/2 pipe to 8AN
with a 3rd port of 1/8 pipe... I have MANY fittings
in the drawer but I cant say I have seen what he wants
but a drill and tap would be easy... right on the hex
Re: Fuel gage fitting help [Re: MR_P_BODY] #1441057
05/24/13 12:17 PM
05/24/13 12:17 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i seriously doubt anyone makes that fitting and can't think of any 1/2" x -8 adapters that have a wide enough hex to drill and tap for 1/8" NPT. best you could probably do is use a 3/8 x 1/2 bushing
Re: Fuel gage fitting help [Re: jamesc] #1441058
05/24/13 12:36 PM
05/24/13 12:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I did as suggested. 1/2" pipe to 8an adapter that I drilled and tapped for an 1/8" pipe fitting for a pressure gauge.
Re: Fuel gage fitting help [Re: Al_Alguire] #1441059
05/25/13 09:18 AM
05/25/13 09:18 AM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
Thanks for the help. I already am using a 3/8 -1/2 adapter, but I want to eliminate that. Looks like I'll make my own.
