Pics of the diaper I made. #1440879
05/23/13 10:14 AM
05/23/13 10:14 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I made card board templates and then traced them onto the fabric. It fits a Milodon pan.
Then I cut it out and my wife sewed it up for me.
Re: Pics of the diaper I made. [Re: rt66jim] #1440880
05/23/13 10:31 AM
05/23/13 10:31 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
What material did you use?
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Pics of the diaper I made. [Re: DragDart360] #1440881
05/23/13 11:06 AM
05/23/13 11:06 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Re: Pics of the diaper I made. [Re: rt66jim] #1440882
05/23/13 11:13 AM
05/23/13 11:13 AM
Az
Crizila Offline
Crizila  Offline
Az
Nicest one I've ever seen!
Fastest 300
Re: Pics of the diaper I made. [Re: rt66jim] #1440883
05/23/13 11:40 AM
05/23/13 11:40 AM
michigan
64ssmax Offline
64ssmax  Offline
michigan
How much are you making them for??? Hint hint!
I would take one. seriously!
Brian
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
Re: Pics of the diaper I made. [Re: Crizila] #1440884
05/23/13 11:54 AM
05/23/13 11:54 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Thank you sir. Jim
Re: Pics of the diaper I made. [Re: rt66jim] #1440885
05/23/13 12:44 PM
05/23/13 12:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
nice but i think depends would probably fit you just fine..
Re: Pics of the diaper I made. [Re: rt66jim] #1440886
05/23/13 01:03 PM
05/23/13 01:03 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Wow good job!I applaud people who take the time effert to make things and make them better in some cases.
Re: Pics of the diaper I made. [Re: Quicktree] #1440887
05/23/13 01:05 PM
05/23/13 01:05 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Sometimes I think I need them. But most of the time not. Jim
Re: Pics of the diaper I made. [Re: rt66jim] #1440888
05/23/13 01:05 PM
05/23/13 01:05 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
10 times nicer and better made than the 180.00 crap I bought from Russleri
home of the
Sox and Martin Hemi Duster
Re: Pics of the diaper I made. [Re: rt66jim] #1440889
05/23/13 01:08 PM
05/23/13 01:08 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Just out of curiosity.. any idea how that material will hold up to the heat? specially when it gets close to headers...
Re: Pics of the diaper I made. [Re: Jeepmon] #1440890
05/23/13 01:33 PM
05/23/13 01:33 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I don't know for certain...but since it is nylon I would say it would probably melt ~400°F...so, if it was too close to the headers you would probably have black goo.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Pics of the diaper I made. [Re: Jeepmon] #1440891
05/23/13 01:39 PM
05/23/13 01:39 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I will let him answer the question about the material he used but I called Jegs and asked about their J&J performance model. He asked, are the headers coated, in my case no, how close to the header? In my car I have one tube on my Headmen headers that I had to do some clearancing with a 4 pound hammer with the Milidon oil pan I used. He said I would have to clearance it some more and use header wrap or it would melt. Looks like my options are different oil pan, relocate one tube, or remove oil pan and modify. Not required for me right now so it looks like a Winter Project.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Pics of the diaper I made. [Re: Jeepmon] #1440892
05/23/13 01:43 PM
05/23/13 01:43 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Well I wasn't sure about it myself. So I also purchased som of this. http://www.ebay.com/itm/400439778196?item=400439778196&viewitem=&vxp=mtr To sew to the outside where it would be exposed to the most heat.
The one pictured is used on a car with fenderwells. Heat is not an issue for him. Jim
Re: Pics of the diaper I made. [Re: rt66jim] #1440893
05/23/13 02:37 PM
05/23/13 02:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thank you sir. Jim
That is nice..... I can appreciate people that make
stuff ... did your wife use a standard machine
or is it a heavy duty ... I figure its a very heavy
duty machine(maybe a commercial) to sew the straps on
Re: Pics of the diaper I made. [Re: MR_P_BODY] #1440894
05/23/13 02:48 PM
05/23/13 02:48 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Actually Mike she used her home machine. But it is a Bernina that is almost 40 years old. Jim
Re: Pics of the diaper I made. [Re: rt66jim] #1440895
05/23/13 02:59 PM
05/23/13 02:59 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Good idea, and nice work!
Re: Pics of the diaper I made. [Re: rt66jim] #1440897
05/23/13 07:01 PM
05/23/13 07:01 PM
Lehigh Acres, Florida
rickstershemi Offline
Applause Given Here.....Very cool....both you and your wife both are very talented...major impressive !!!!!
Rickster
Re: Pics of the diaper I made. [Re: rt66jim] #1440898
05/23/13 10:12 PM
05/23/13 10:12 PM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
That's a really professional looking diaper--you should be proud of your handiwork. FWIW--I have a J&J diaper, the straps under the center exhaust ports started to show signs of melting, I wrapped them in the metallic tape that is used by HVAC contractors, solved the problem.
Re: Pics of the diaper I made. [Re: reknapp52] #1440899
05/23/13 11:47 PM
05/23/13 11:47 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Thanks for all the positive replies. Maybe I need to go into business? I can see it now Diapers by Jim.
