Who has used a chassis dyno and did it help your tune? #1440573
05/22/13 03:59 PM
05/22/13 03:59 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
The local Import Tuner shop that did my Subaru WRX "makeover" last year has a chassis dyno. That got me wondering about whether it would be a benefit to strap The MoPig (once running, obviously) down on it to see how it performs, maybe get some baseline air-fuel curve #s, etc.
Their shop foreman runs an Outlaw 10.5" Chebby, so it's not like they don't know what a carbureted American V8 is. Also, they seemed pretty interested in having my car on their chassis dyno after showing me videos of a 700+ RWHP modified supercharged Shelby 'stang on it.
So, who here has used a chassis dyno and did it really help w/ getting your tune dialed in? Or should I save the $$$ for test & tune entry fees at the track and dial it in the old fashioned way?
Re: Who has used a chassis dyno and did it help your tune? [Re: BradH] #1440574
05/22/13 04:25 PM
05/22/13 04:25 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Usually the track is too crowded to make enough passes to try different things to see what works best. So the dyno makes much more sense for tuning experimentation. You can see immediately what helps and what hurts without some of the inconsistencies that happen at the track if you are strictly comparing timeslips. The wideband and graphing capabilities on the dyno help a ton.
The dyno has also helped me diagnose transmission problems correctly when I couldn't really pin down the problems at the track.
Imagine what this felt like? hehehe
You will still need to play with things like launch rpm and tire pressures at the track - but at least you can already be done tweaking things on the engine.
Re: Who has used a chassis dyno and did it help your tune? [Re: Duner] #1440575
05/22/13 04:28 PM
05/22/13 04:28 PM
BradH Offline OP
BradH  Offline OP
Those graphs look like my 5-year old daughter drew 'em.
I don't understand how the data can do things like that on a legit pull.
Re: Who has used a chassis dyno and did it help your tune? [Re: BradH] #1440576
05/22/13 04:30 PM
05/22/13 04:30 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
This is not a dragracer, but just a dailydriver which I tuned for 1.5 year by ear, buttdyno, vacuum- and AFR-gauge.
I went to the dyno just to get a baseline HP-number and to see what the low cr 318 still put out.
At the location after the first run the shop-owner asked if I wanted to try something on the engine to see if there's more in it.
I didn't bring anything useful but I decided to try some minute changes in timing and mixture adjustments.
All the changes I did during the 5 consecutive runs made the engine put out less HP then the first run...
Was nice to find out I have a well calibrated buttdyno...!
This reply is of not much use in a racecar but just felt like sharing anyway...
Re: Who has used a chassis dyno and did it help your tune? [Re: BradH] #1440577
05/22/13 04:38 PM
05/22/13 04:38 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
The transmission was slipping in and out - so when the rpms fluctuated vs the load it went all crazy. It felt like a bucking bronco from the driver's seat. A straight engine rpm vs dyno roller speed graph showed it pretty clearly.
Re: Who has used a chassis dyno and did it help your tune? [Re: BradH] #1440578
05/22/13 04:55 PM
05/22/13 04:55 PM
AndyF Offline
AndyF  Offline
I did a lot of chassis dyno work a few years ago. In fact, for a while I had a standing Friday morning date at the dyno shop. I eventually ran out of money but it was fun while it lasted.
I swapped intakes, carbs, air cleaners, ignitions, etc. on the dyno. We played with tire pressure and tire size and other things. I did several different cam swaps between dyno dates and generally tested a ton of combos.
I like the chassis dyno but there are a lot more variables than an engine dyno so you have to be careful about what you're testing. My car has a manual trans (Doug Nash 5 speed) so the tests were consistent and fairly easy to understand.
Re: Who has used a chassis dyno and did it help your tune? [Re: Duner] #1440579
05/22/13 05:01 PM
05/22/13 05:01 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I used to run a chassis dyno and it did help with tuning but depending on the style, it can cause other issues. If it's a brake style then it'll work just fine for tuning, but if it's an inertia style then the engine will think the car is only as heavy as the drum the wheels are spinning. So if you have a hesitation while driving but tune it out on an inertia style dyno, it'll probably still be there when you take it out on the street. It really helps to have some sort of O2 reader to tie into it though I didn't always use that and would just make back to back tests after changing timing or jetting. Always go richer first (if there's no O2 sensor) and lower the timing first as this can prevent damage if you're borderline to start with.
Re: Who has used a chassis dyno and did it help your tune? [Re: AndyF] #1440580
05/22/13 05:19 PM
05/22/13 05:19 PM
BradH Offline OP
BradH  Offline OP
Their dyno does have an air-fuel meter setup, but they can also weld in the bungs I have to test out my LM-1.
For me, the basics (timing, carb tuning) are the primary areas of interest, since I know that there are so many other things that require on-track testing to figure out.
Since it's a new top-end & cam combination on top of a freshened bottom end, I don't know what to expect from it compared to the old combination. I was thinking that having at least some baseline tune before hitting the track could be a time saver...
Re: Who has used a chassis dyno and did it help your tune? [Re: BradH] #1440581
05/22/13 05:32 PM
05/22/13 05:32 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i did, had the A/F perfect on the dyno. got to the track and it was almost a second slower. leaned it out and went back to where we were.
Re: Who has used a chassis dyno and did it help your tune? [Re: Quicktree] #1440582
05/22/13 05:52 PM
05/22/13 05:52 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
we take our dirt car to WILLY'S carb & dino before we ever race each year,when he's done theres not 1/10 hp that your combo can produce left in your car, i hily recomend him & getting it done
Re: Who has used a chassis dyno and did it help your tune? [Re: jg309] #1440583
05/22/13 06:57 PM
05/22/13 06:57 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I had my truck intially tuned "on the street" to get a baseline. Of course, on the street you can't get too much speed, etc., so we finished on the dyno. That got us pretty close where the fine-tuning was done at the track.
Re: Who has used a chassis dyno and did it help your tune? [Re: BigBlockMopar] #1440584
05/22/13 06:57 PM
05/22/13 06:57 PM
Penna
70satelliteguy Offline
Penna
"BigBlockMopar "
Did the Dyno you used have a roof leak?
Mike
Re: Who has used a chassis dyno and did it help your tune? [Re: Quicktree] #1440585
05/22/13 11:59 PM
05/22/13 11:59 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
why would that be? were you tuning for most hp on the dyno or best A/F?
Re: Who has used a chassis dyno and did it help your tune? [Re: sixpackgut] #1440586
05/23/13 12:35 AM
05/23/13 12:35 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I chassis dyno lots of cars but you guys can keep your AF meters i pull plugs.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Who has used a chassis dyno and did it help your tune? [Re: sixpackgut] #1440587
05/23/13 12:41 AM
05/23/13 12:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have been on a dyno twice... once was on Woodward
ave. for a demo run for show and tell... my car got
rained on sitting on my open trailer out there and it
poured water in my dist... I didnt know this untill
after I was up past 4000 rpm and it started breaking
up... then I went on Jakes dyno a few weeks later just
for kicks to see what it made
Re: Who has used a chassis dyno and did it help your tune? [Re: MR_P_BODY] #1440588
05/23/13 01:24 AM
05/23/13 01:24 AM
Waterford,NY
V
Vintage Offline
Vintage  Offline
V
Waterford,NY
Anyone tune nos on a chassis dyno? Not fine tune but to check basic function of a system?
Re: Who has used a chassis dyno and did it help your tune? [Re: sixpackgut] #1440589
05/23/13 05:51 AM
05/23/13 05:51 AM
Q
Quicktree Offline
Quicktree  Offline
Q
A/F with a new e-85 carb.not really concerned about hp. looking more for consistency
Re: Who has used a chassis dyno and did it help your tune? [Re: 70satelliteguy] #1440590
05/23/13 06:13 AM
05/23/13 06:13 AM
The Netherlands
The Netherlands
"BigBlockMopar "
Mike
This was needed as extra cooling for the room to counter the heat from all that horsepower my little pony-Dart put out...
Re: Who has used a chassis dyno and did it help your tune? [Re: BigBlockMopar] #1440591
05/23/13 11:10 AM
05/23/13 11:10 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Sorry to highjack but while where on the subject.
I know of a chassie dyno pretty close to me and not very expensive but...
The guy have not lowered the rollers into the floor. So the car would be very tilted forward.
Would that effevt the carb in abad way???
I belive so cause the float levels would be very off.
What do you guys think???
Re: Who has used a chassis dyno and did it help your tune? [Re: sshemi] #1440592
05/25/13 08:11 AM
05/25/13 08:11 AM
sweden
sshemi Offline
sshemi  Offline
sweden
No one???
