Several 440 questions #144027
10/31/08 05:19 PM
10/31/08 05:19 PM
Anonymous OP
Anonymous OP
I'm currently building a low miles 440 (original bearings,no bore ridge,etc) to emulate the Car Craft 535hp buildup from 2001(Dulcich currently has the longblock(built it,too?)based on reading between lines over the years).
Anyway, the only changes from that build are I'm using a Hughes ported RPM intake, and a 275XE cam(they used 274XE w/1.6 rockers, so it's a wash overall).
My Q's are- since CC didn't change the springs on the Eddy heads, will I be ok too?
Another, they retained the stock main bolts-will that suffice if I pass inspection? I feel no tight spots and there are no nail catches, plastigauges(I know) @ .002-.003 on all mains.
I will have it checked @ Bischoff's of Enginemasters fame(just 15 miles away!) to be certain-these are just preliminary checks,just trying to get an idea of what is needed. Should I consider a girdle at this point? I will go to at least studs if an align hone is done,as it is.
Oh, one other change is going with either KB forged or JE/SRP- still made in USA, unlike Speed-Pro(BOOO!), and probably Total Seal Top Gapless rings.
Re: Several 440 questions #144028
10/31/08 05:30 PM
10/31/08 05:30 PM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
Eddy heads are good to .600 lift
SRP pistons are what I use.
Re: Several 440 questions [Re: DAMOPARS] #144029
10/31/08 08:27 PM
10/31/08 08:27 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
What you should say is the heads are setup with retainer to guide clearance for a .600 lift cam , if one were going to use the heads on a motor with a soild roller with under .600 lift those springs would still be useless .
Ignore the springs supplied with the heads unless you have the SPECS for them and then compare the specs to the specs the CAM MAKER calls for , if they work , great , if not buy the correct springs .
Re: Several 440 questions #144030
11/01/08 04:13 AM
11/01/08 04:13 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
See if eddy's spring specs match what your cam wants. If not, replace them. Either ARP main bolts or studs would be a good idea. Many people have gotten by without them so it is your choice. Girdle is not necessary at this power level. Pistons are your choice, go with something with a 2.060 or greater compression height.
Re: Several 440 questions [Re: DaytonaTurbo] #144031
11/01/08 10:57 AM
11/01/08 10:57 AM
Anonymous OP
Anonymous OP
Thanks for the assurance- I appreciate it!
Re: Several 440 questions #144032
11/01/08 03:55 PM
11/01/08 03:55 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The Car craft 440/RPM head engine was in a few different articles with different cams and intakes. I think one thing they did not mention is the block must have been milled to get the compression ratio/deck height they quote on the story, but the engine was really impressive, expecially the torque numbers.
In one article, I think in Mopar Muscle, they used a Hughes cam that was simular the the Comp cam, and they mention they needed to change the valve springs out. I think they even said the power was down a bit before the changes because the Edelbrock valve springs were loosing pressure with the Comp cam?
As for the bottom end, you don't need a girdle, but main studs would be a good idea. If your on a tight budget the ARP main bolts are not too expensive and would be an upgrade over the stock bolts.
I'm not sure you mentioned connecting rods, but at a minimum, install ARP rod bolts and have the rods checked and re-conditioned. There are a bunch of afforadable aftermarket rods avaliable you may want to consider also. For example many of these rods (like 440-source) use the 7/16" ARP 2000 rod bolts.
Re: Several 440 questions [Re: 451Mopar] #144033
11/01/08 04:37 PM
11/01/08 04:37 PM
Anonymous OP
Anonymous OP
Cool-I wasn't going to skimp on rod bolts.
I've seen that same 440 since then in more than a few articles, as mentioned. Glad I'm not the only one.
I'll probably go with bolts if Bischoff says it doesn't need align honed.
