Honestly you have a good set-up with the single dominator, but if you put duals on it, QF or ProSystems would get my vote...Because, depending on the fuel, the calibration is different. I am pretty sure you run pump gas in that behemoth, and if Holley still jets to the book, they will be off the target A/F with today's E10 crap pump gas...So you really NEED a custom carb. With E10, the target A/F ratio needs to be richer than with non-E10 fuel, and that is somthing a lot of people are not adjusting for.
If it were mine, I would run a single SV1 Pro Systems carb on it...Bet its nearly equal to a tunnel ram...
