holley vs quickfuel #1439778
05/21/13 07:51 AM
05/21/13 07:51 AM
pa
572charger Offline OP
pa
holley hp 850s or quickfuel black diamond 850s on a indy tunnel ram anybody with any real world insite on comparing the 2 ?? 606cuin pump gas hemi
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: holley vs quickfuel [Re: 572charger] #1439779
05/21/13 10:46 AM
05/21/13 10:46 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Honestly you have a good set-up with the single dominator, but if you put duals on it, QF or ProSystems would get my vote...Because, depending on the fuel, the calibration is different. I am pretty sure you run pump gas in that behemoth, and if Holley still jets to the book, they will be off the target A/F with today's E10 crap pump gas...So you really NEED a custom carb. With E10, the target A/F ratio needs to be richer than with non-E10 fuel, and that is somthing a lot of people are not adjusting for.
If it were mine, I would run a single SV1 Pro Systems carb on it...Bet its nearly equal to a tunnel ram...
Re: holley vs quickfuel [Re: Dragula] #1439780
05/22/13 07:36 AM
05/22/13 07:36 AM
pa
pa
just wanna put the t ram back on the new holley hp 850s look to be on the rich side thats what im leaning toward i still have the ray barton single dominator intake and a pro systems 1200+ carb ran 9.60s that way on pumpgas and motor only want to see how far off t ram will be on the fresh motor !thanks for the reply !!!
