Holley Experts Help Please #1439720
05/20/13 11:46 PM
05/20/13 11:46 PM
Iowa
Rodder Offline OP
Rodder  Offline OP
Iowa
I have a 408 stroker that I run a 780 Holley double pumper on and it runs well. I am experimenting with an 850 DP to see if it gains anything. I am having trouble with the carb not idling at all. It will start up and run great at about 1800 and above. It is crisp and responsive. But if I try to idle it at all it just dies like you turned the key off. I can't even turn it down past 1500 or it just dies, no cough no sputter. My old 780 DP carb idles just fine. Whats goofed up in this carb that it won't idle at all. The floats are set correctly. It is fed by an electric fuel pump. Jets are 72 and 76. Power valve is 3.5. I have had it apart and cleaned and blew out every passage.
Re: Holley Experts Help Please [Re: Rodder] #1439721
05/21/13 12:11 AM
05/21/13 12:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
open up the mixture screws... you should be able to
go up to 3 turns out IF NEEDED... at 1800 rpm its
not on the idle circuit.... start at 2 turns out then
turn the idle down and turn the mixture screws in till
the idle drops... this part takes 2 or 3 times to
get the balance..... make sure the timing is right
before you start this... sometimes you need to up the
initial timing
EDIT
I forgot to say... when the rpm drops turns the mixture
screw out about 1/8 of a turn... then do it all again
till you get the idle where you like it
Re: Holley Experts Help Please [Re: Rodder] #1439722
05/21/13 12:12 AM
05/21/13 12:12 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Not an expert but you may want to check you carb number on this chart to get a starting point. I don't use power valves myself as my junk is strip only and I leave off the brake.
http://tgsperformance.com/holley.htm
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Holley Experts Help Please [Re: Rodder] #1439723
05/21/13 08:53 AM
05/21/13 08:53 AM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
It just happen to me,I had just rebuilt it last year and had not run it since till 2 weeks ago.After cleaning again air bleeds still woun't work I took it back apart and fount that I had the wrong base plate gasket on it the holes was in the wrong place and stopped the gas.
Section 8 Racing We are nuts about racing.
