I have a 408 stroker that I run a 780 Holley double pumper on and it runs well. I am experimenting with an 850 DP to see if it gains anything. I am having trouble with the carb not idling at all. It will start up and run great at about 1800 and above. It is crisp and responsive. But if I try to idle it at all it just dies like you turned the key off. I can't even turn it down past 1500 or it just dies, no cough no sputter. My old 780 DP carb idles just fine. Whats goofed up in this carb that it won't idle at all. The floats are set correctly. It is fed by an electric fuel pump. Jets are 72 and 76. Power valve is 3.5. I have had it apart and cleaned and blew out every passage.
