Valve cover clearance....small block (F.A.S.T. guys)?? #1439346
05/20/13 07:58 AM
05/20/13 07:58 AM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
Alright you LA guys...Help a big block/Hemi guy...
I am working on a small block Dart Swinger 340. The motor has Crane Gold's. What are my valve cover options if I want stock appearance? The customer had given me some Direct Connection chrome covers which I know arent stock appearing but he would go with them...They look like they will not work, even if I took the oil baffles out.
BTW its NOT a FAST type of car, so we dont HAVE to have a stock cover on it, just something that is "Kinda" stockish..
Anyway, lets hear your opinions on my options here....Want to get this one out of here...
MB
Re: Valve cover clearance....small block (F.A.S.T. guys)?? [Re: HPMike] #1439347
05/20/13 08:43 AM
05/20/13 08:43 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Mike,
I had to peen in the baffle on mine in about four spots because the adjuster would make contact. My rockers do not have real tall adjusters like some I have seen.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Valve cover clearance....small block (F.A.S.T. guys)?? [Re: HPMike] #1439348
05/20/13 08:52 AM
05/20/13 08:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Try 2 gaskets....
Re: Valve cover clearance....small block (F.A.S.T. guys)?? [Re: Rapid340] #1439349
05/20/13 08:57 AM
05/20/13 08:57 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I drag my plasma cutter right through the center of the baffle, then I peel the two halves open and clean out all the junk that is hiding up there, then I fold them back together with clearance in mind and tac weld then in their "A frame" position.
I've had the biggest rockers never touch anything. I do the same treatment on the big blocks too. Mostly to clean out the junk.
Re: Valve cover clearance....small block (F.A.S.T. guys)?? [Re: Rapid340] #1439350
05/20/13 10:31 AM
05/20/13 10:31 AM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
Mike,
Thanks all
Jeff, I assume you are running a stock valve cover?...no?
MB
Re: Valve cover clearance....small block (F.A.S.T. guys)?? [Re: HPMike] #1439351
05/20/13 11:37 AM
05/20/13 11:37 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I sell these spacers, 3/16" thick...
Re: Valve cover clearance....small block (F.A.S.T. guys)?? [Re: topside] #1439352
05/20/13 11:45 AM
05/20/13 11:45 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I was getting ready to find the link to your spacers, you saved me the trouble.
My 340 had the Moroso chrome valve covers over the Crane Gold rockers without any clearance issues, although there are no baffles inside.
Re: Valve cover clearance....small block (F.A.S.T. guys)?? [Re: Dave Watt] #1439353
05/20/13 08:54 PM
05/20/13 08:54 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
MB
yes, stock 340 valve cover
Re: Valve cover clearance....small block (F.A.S.T. guys)?? [Re: Rapid340] #1439354
05/20/13 11:38 PM
05/20/13 11:38 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Same deal. Stock valve covers, just took the baffle out. Clears the harland sharps no problem.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Valve cover clearance....small block (F.A.S.T. guys)?? [Re: topside] #1439355
05/21/13 12:40 AM
05/21/13 12:40 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I have a set of these spacers to put under my valve covers for use with sharps and a .600 lift cam
The spacers are real nice for the money.
