Re: 400" R5/P7
[Re: Leon441]
#1439106
06/01/13 07:12 PM
06/01/13 07:12 PM
Posts: 4,421 in a chair
mopartony
in a chair
Leon, I thought I had put in my post. I am using a Bruno. I just had it made in Feb. They had a NASCAR bell to take the pattern from. They never said anything about making one specifically for the R5 block. I am going to run a Meziere flex plate/flywheel and either a 7 or 8" convertor. I also wanted to keep the R5 starter location. maybe that and the Bruno is why they cannot do it specifically for the Bruno. Sorry about not giving that detail about the Bruno I thought I had it in there. thanks for the heads up on the adapter Bob makes. I should get a hold of Bob before I go having an adaptor made. I am not worried about the firewall area. It is going in a full tube car. I am hoping to still use the NASCAR headers too.
Re: 400" R5/P7
[Re: mopartony]
#1439107
06/02/13 07:49 AM
06/02/13 07:49 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Some aftermarket bells have enough material to redrill for a R5 pattern. Then you just need a flywheel with 130 tooth starter gear. Then just run the mopar starter. Pretty simple. It is not legal with SFI to redrill the bell. That is considered a modification. If you get the same thing done with a Browell bell you can bolt right up and use a Mopar starter. Less stuff to do with the flywheel if you have a chevy style flange on the crank.
The R5 to Mopar small block overlaps the dowel pins and a couple bolt holes. The above the starter is almost unuseable. I don't know on the R5 to chevy bell. Have seen them but, don't remember how bad it is. I think the dowels are better.
Re: 400" R5/P7
[Re: mopartony]
#1439109
06/02/13 08:32 PM
06/02/13 08:32 PM
Leon441
Lynchburg, VA
I will PM you Tony as Rick does not need this post hijacked any further.
Re: 400" R5/P7
[Re: Leon441]
#1439110
06/02/13 10:15 PM
06/02/13 10:15 PM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
I don't at all as it's been good technical info.
Now if we start talking about paint jobs or wishing someone a happy birthday.........
Re: 400" R5/P7
[Re: Streetwize]
#1439112
06/03/13 09:20 PM
06/03/13 09:20 PM
Leon441
Lynchburg, VA
Maybe I can explain where Tony left off. Some bolt holes on the R5 were in the radius of the Browel bell. So they sold him a bell for a BB Mopar and then adapter to go back to R5. This is probably a better adapter as no bolt holes or dowels will be close to each other.
Re: 400" R5/P7
[Re: Leon441]
#1439114
06/04/13 05:05 PM
06/04/13 05:05 PM
mopartony
in a chair
Leon is right. But with the BB Mopar bolt pattern you will need to use the R5 starter location. Which is in the bell I got. Using the small block adapter you can use the normal starter.
Leon, that part just dawned on me. That is one reason I didn't go with the Jesse or Bobs set up. I felt with the Bruno it would space things out too much. The adapter thickness is figured into the bell housing for the correct convertor length...
Sorry these detail have slipped my memory at this time as I have been working other issues with the car and work is nothing but numbers, lengths and stuff like that... Could be CRS too
