Re: 400" R5/P7
[Re: LSP]
#1439087
05/19/13 10:10 PM
05/19/13 10:10 PM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
Hope parts are easier to get than my R4/P5 engine. Good luck and keep us posted!
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: 400" R5/P7
[Re: W8n2DustU]
#1439089
05/21/13 06:59 AM
05/21/13 06:59 AM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
Yeah, this R5/P7 stuff is surely more common than the PS Truck stuff.
Re: 400" R5/P7
[Re: LSP]
#1439090
05/25/13 02:00 PM
05/25/13 02:00 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Do you have any cranks with 3.600 or more stroke?
My 3.25" is not a great match for the 2 spd tranny.
Re: 400" R5/P7
[Re: Leon441]
#1439091
05/25/13 08:56 PM
05/25/13 08:56 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Should make an awesome combo. I know there are a lot of Trophy Trucks that run 440+" SB2 and Roush headed combos to achieve 800+hp reliably. Same should be expected from the Mopar camp.
Mopar to the bone!!!
Re: 400" R5/P7
[Re: Leon441]
#1439092
05/26/13 08:00 AM
05/26/13 08:00 AM
LSP
Charlotte, NC
No, I'm going with a 4.250" x 3.520" bore/stroke combo, Rick at King's Crankshaft can make any stroke you want.
Re: 400" R5/P7
[Re: 72Swinger]
#1439093
05/26/13 08:03 AM
05/26/13 08:03 AM
LSP
Charlotte, NC
Yes, those guys are around 880-900 hp, I expect more than that.
Re: 400" R5/P7
[Re: LSP]
#1439095
05/31/13 09:25 AM
05/31/13 09:25 AM
Leon441
Lynchburg, VA
That bore and stroke should make a great gutless high horsepower monster. Great comp motor. Put a stick behind it and you got one bad combo.
Re: 400" R5/P7
[Re: Leon441]
#1439096
05/31/13 08:15 PM
05/31/13 08:15 PM
LSP
Charlotte, NC
It would be just fine in front of an automatic as well, a 7" converter flashing between the peaks is usually a good place to start on a motor like this.
I got it just to see what it might do on the pump set up as a 400 CI, cast intake/4500 drag motor.
Re: 400" R5/P7
[Re: LSP]
#1439097
05/31/13 09:39 PM
05/31/13 09:39 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
I,m still in the testing stages, Glide, with 7" verter,stalling to 8500. Going to go up on gears so, from 488 to 600, trying to find my 60'. Rite now my mph is 140, but going threw traps at 7800, n shifting almost at the 1/8. Good Luck with the build
Re: 400" R5/P7
[Re: B1KILLER]
#1439098
05/31/13 10:07 PM
05/31/13 10:07 PM
Leon441
Lynchburg, VA
I made a few passes with a 4.10 gear and 31" tires. I shifted at 9K in the MPH lights in the eighth. The 6.17 gear is much better for 1/8 mile but just does not quite get the 1/4 mile done.
I tried the 7" for gutless motors and picked up nothing in 60 ft. and lost overall.
There is only one way to go with a powerglide and heavy car. That is stroke in the crankshaft.
Rick what is the wall thickness with the 4.250 Bore?
Re: 400" R5/P7
[Re: Leon441]
#1439099
05/31/13 10:41 PM
05/31/13 10:41 PM
LSP
Charlotte, NC
.300" minimum on my block.
Re: 400" R5/P7
[Re: LSP]
#1439100
05/31/13 10:43 PM
05/31/13 10:43 PM
Leon441
Lynchburg, VA
Can run that all day long.
Re: 400" R5/P7
[Re: Leon441]
#1439101
05/31/13 10:43 PM
05/31/13 10:43 PM
Posts: 11,712 Portage,michigan
B3422W5
Portage,michigan
I am curious as to why a glide is being used unless the sole intent is to bracket race the car and ultra consistency and not running the best ET are the aims. My buddy campaigned a dinky cammed 12 to1 r5 p7 3000 pound Dart with a 28 by 10.5 tire and 4.56 gears and with. next to no messing around at all got it to run 143 mph and 60 foot 1.28 and 1.29 with a 904 trans. Guess I don't understand all the glide struggles and convertor woes.i know his convertor likely wasnt even optimal( just guessed about where it should flash and sent it to Ptc then threw it in the car....
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: 400" R5/P7
[Re: B3422W5]
#1439102
06/01/13 09:06 AM
06/01/13 09:06 AM
Leon441
Lynchburg, VA
Other than the 60 ft your buddies thrown together combo is nothing special. I am running a glide because it is what is in the car. Would be running a Pro Trans but Dave never had the decency to call back after I spent days trying to get him to answer the phone and then an hour going over the dyno sheets and car. My 60 ft is nothing special 1.32 in great air. That was with an ole PTC 6,800 converter. I ran 5.82 in the eighth also in good air. 119 MPH in the eight which is only about 800-840 HP with any bracket motor combo. At 1000 ft the car was well over 140 MPH. Did not know the full RPM limit of the rods. Lifted around 1100ft and still ran a 9.27@127 to say I was on the brakes heavy is an understatement. So tell me just how dumb am I for running a powerglide. When building the next project with the P7 heads explain why the 904 will not hold up with power adders. Ran torque flites for years. But, with the 25.2 chassis a stock length tail housing does not fit. The Proflite is the only option and it will not work with power adders. So why spend $10,000 to run a little faster one season. Actually would have done it a few months ago but, remember Dave didn't want the business enough to give me a quote and take my money. Oh rant over that's why I am running a powerglide. Leon PS If a P7R5 guy is smart and has the money a Browel bell and a 5 spd is the smart way to go. No adapters no BS just a clean sheet of paper.
Re: 400" R5/P7
[Re: Leon441]
#1439103
06/01/13 10:03 AM
06/01/13 10:03 AM
LSP
Charlotte, NC
If my motor were to end up in a car, I'd check into getting an undrilled Ultrabell for an automatic. ATI already offers kits to bolt up a TH400 BOP that I could fall back on if I had to.
Re: 400" R5/P7
[Re: Leon441]
#1439104
06/01/13 03:59 PM
06/01/13 03:59 PM
Posts: 4,421 in a chair
mopartony
in a chair
Leon, not trying to step on your toes on this as you are one of the guys i look to for answers on the R5 stuff. But I know the adapter is needed, I have the Browell Bell and Liberty 4spd Extreme at the chassis shop going into the new car. I need to have the adapter made. I have it all modeled in CAD, just need someone to water jet and CNC it. I have the shorter housing like 6.875 I think. With a .75" thick adapter I can run a non lock up convertor.
Re: 400" R5/P7
[Re: mopartony]
#1439105
06/01/13 06:22 PM
06/01/13 06:22 PM
Leon441
Lynchburg, VA
Tony you guys did not buy the Browell bell to fit the R5? I talked to JW, ATI, and Reid in great length at PRI. SFI certifies the bell after it is drilled. Reid says he get something like 30 done at a time. Unless he could take the small block casting and drill it for R5 and do enough to pay for the trouble it is not going to happen. The ATI does not have enough material in the right places. The Reid looked like it did. I have a JW and have the whole time I have ran this Glide. Not going to do this again. If the trouble is going to be gone through I will plug and redrill a Reid bell and replace the case with a Reid. Sheilds and JW stuff bolting to the pump is something I would like to do away with.
The current engine in my car uses the 8 bolt Ford flange. So there is not much sense in getting rid of the adapter. But, once I do something else like an EEI block with a chevy flange crank. All the rest of this stuff will get cleaned up.
Bobsprofab sells an adapter. I made some changes sense I have a bolt at 12 O'clock and could clean up some things on it. The ATI deal is an adapter that goes to an Olds or Pontiac Bell. Major firewall work to clear the top of that bell. R5P7 Bantom has that configuration. Works great in an altered terible with a stock firewall.
Leon
