The nitty gritty...
Dear Eric:
Thank you for contacting the Ram Customer Assistance Center.
In response to your email, we are pleased to provide vehicle build
information as you requested. As per our records, your vehicle
(VIN:1D7KS28C27J551361) was equipped from the factory with the
following:
*M9 Cloth 40/20/40 Prem Bench Seat
-J3 Khaki
AHCP Trailer Tow Group
AL1 Quad Cab Lone Star Value Group
APAS Monotone Paint
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BRTS Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CG1S Next Gen Multistage Front Air Bags**
CKES Floor Covering Carpet
CLE Front & Rear Floor Mats
CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CUMP Mini Floor Console
CUSS Overhead Console w/Trip Computer
CVHP Front Center Seat Cushion Storage
CVN Folding Flat Load Floor Storage
DGBS All 4-Speed Automatic Transmissions
DG8 4-Spd. Automatic 48RE Transmission
DH1S Man Shift-on-the-Fly Transfer Case
DJQS 5,200# Front Axle
DMES 3.73 Rear Axle Ratio
DRQP 11.50 Rear Axle
DSA Anti-Spin Differential Rear Axle
ETH 5.9L I6 HO Cummins TD Engine
GACS Tinted Glass Windows
GFDP Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNMS Passenger Side Sun Visor w/Mirror
GPG Power Black Trailer Tow Mirrors
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JAYS Instrument Cluster w/Tach
JBYS Instr. Panel Color Keyed Bezel
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKYS Power Accessory Delay
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JRDP Power Driver Seat
JTHP Power 6-Way Driver Seat
K1XP Jet Black - Molding - Bodyside
K17P Bodyside Molding
LMAS Halogen Headlamps
LNJP Fog Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MFDS Bright Grille
MGAS Ram's Head Badge
MHAS Black Windshield Moldings
MTDS SLT Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MYGP Lonestar Badge
NAA Federal Emissions
NFUS 34 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCS Heavy Duty Engine Cooling
NZCP Current Generation Eng Controller
PRH Inferno Red Crystal Pearl Coat
QRHS Inferno Red Crystal Pearl Coat
RAAC All Radio Equipped Vehicles
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
REFS AM/FM Compact Disc Radio
RSAP Sirius Satellite Radio
SBES Power Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TT3S LT265/70R17E BSW All Season Tires
TZHP Michelin Brand Tires
WF1S 17" Steel Spare Wheel
WGDP 17X8.0 Forged Aluminum Wheels
WLZC All Aluminum Wheels
WMJP Center Hub
XA8S Non Adjustable Pedals
XBSS Pickup Box
XEAP Tow Hooks
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XGWP Stain Repel Seat Fabric
X9AP For More Info, Call 888-539-7474
X97P 1-Year Service Provided by SIRIUS
YAAS Build To U.S. Mkt. Specifications
