Replacement for my totaled 04.5' #1438785
05/19/13 12:41 PM
05/19/13 12:41 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Hopefully it's as good a truck as the last. pulled the trigger yesterday.
http://www.illinoisautobrokers.com/web/1096/vehicle/1344693/2007-Dodge-Ram%202500-SLT
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Replacement for my totaled 04.5' [Re: Eric] #1438786
05/19/13 04:07 PM
05/19/13 04:07 PM
Lehigh Acres, Florida
rickstershemi Offline
Looks clean.....good for you and best of luck with it Eric
Rickster
Re: Replacement for my totaled 04.5' [Re: Eric] #1438787
05/19/13 11:37 PM
05/19/13 11:37 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Couple things...Its an 07, so its an emissions diesel, and really the first year for them.
Two, its got the steeper 3.73 gears...
Three, its an auto...
Other than that, it looks nice.
Towed all the way out to NYIRP with my new '01 Friday for TNT and Saturday for the Gasser's race, which I won...And the new to me truck towed better than my last one with power to spare fully loaded. Still fighting a trailer brake gremlin, but I have it narrowed down. Pulls the big hill leaving back to Batavia fully loaded at 60mph...Also got 15.5mpg fully loaded as well. Looked at a lot of newer diesel Dodges, just couldn't justify the difference in price and worse mileage.
Re: Replacement for my totaled 04.5' [Re: Dragula] #1438788
05/20/13 09:40 AM
05/20/13 09:40 AM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
As far as the emissions diesel thing is concerned...what do I need to know about that?
It is a 5.9...
Re: Replacement for my totaled 04.5' [Re: Eric] #1438789
05/20/13 10:21 AM
05/20/13 10:21 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
it has the same as any other late 5.9 a cat on the exhaust the egr valves and other stuff came with the 6.7
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Replacement for my totaled 04.5' [Re: Dragula] #1438790
05/20/13 11:25 AM
05/20/13 11:25 AM
Kansas
cascius Offline
cascius  Offline
Kansas
Even though it's an '07, it still has the 5.9 so there aren't any emissions on it to worry about. That didn't start until they changed over to the 6.7 engines.
3.73's and 4.10's are the only options for a diesel starting in '03. You can't get 3.55's anymore like you could with the 2nd generation trucks.
The 48RE's really aren't that bad. I prefer them over the G56 transmission any day. If you leave the power level stock you probably won't have many issues. If you are going to turn it up then you will need to look at upgrading it or it won't last long.
Re: Replacement for my totaled 04.5' [Re: cascius] #1438791
05/20/13 11:36 AM
05/20/13 11:36 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
My 09 dodge came from the factory with 3.42 gears.but it was a 6.7. Also if Eric desides to turn the power up a little bit ,at the least I would recommend a after market torque converter and valve body.to bad they don't have a kit out to put a six speed in his o7 like I had in my 09. Nothing wrong with the 48RE I just never liked the big gear change from 3 to 4 gear.Eric that's one great looking truck and is the same color as my 09 was.that truck should last you a very long time.best of luck with it.mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Replacement for my totaled 04.5' [Re: Eric] #1438792
05/20/13 11:48 AM
05/20/13 11:48 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
WOW, that thing is crazy clean for that kind of miles. Nice score!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Replacement for my totaled 04.5' [Re: cascius] #1438793
05/20/13 12:01 PM
05/20/13 12:01 PM
Dragula Offline
Dragula  Offline
Actually, even though its still a 5.9, because its an emissions diesel, you cannot remove the emission devices. It will have an EGR and CAT & muffler...Meaning to pass inspection, the computer must be read, and all devices intact. And with winters around here, they do tend to only last a few years.
On a non-emissions diesel, it is exempt and only costs $10 here in NY for inspection. I don't even have to run an exhaust if I don't want to. And you gain a little towards mpg without it or just going to a bigger pipe without the cat & muffler....Sounds good too. My 2001 is a beast.
Re: Replacement for my totaled 04.5' [Re: Dragula] #1438794
05/20/13 01:08 PM
05/20/13 01:08 PM
Kansas
cascius Offline
cascius  Offline
Kansas
The '07 5.9 does NOT have an EGR valve. That did not come into play until they changed to the 6.7 engines. These engines are exactly the same from 2005-2007. It will have a Catalytic converter and a muffler but no sensors in the exhaust like a 6.7 does. These are the only emissions items that the 05-07 5.9 trucks had.
Re: Replacement for my totaled 04.5' [Re: mopar65] #1438795
05/20/13 01:12 PM
05/20/13 01:12 PM
Kansas
cascius Offline
cascius  Offline
Kansas
I didn't know they brought that option back with the later 6.7 trucks. I know with the 03-07 trucks it wasn't an option. As far as the 6-speed swap, for the money it'd cost to do the swap he could build the 48RE and have a MUCH stronger transmission that would last through anything he wanted to do with it.
Re: Replacement for my totaled 04.5' [Re: cascius] #1438796
05/20/13 02:26 PM
05/20/13 02:26 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
The nitty gritty...
Dear Eric:
Thank you for contacting the Ram Customer Assistance Center.
In response to your email, we are pleased to provide vehicle build
information as you requested. As per our records, your vehicle
(VIN:1D7KS28C27J551361) was equipped from the factory with the
following:
*M9 Cloth 40/20/40 Prem Bench Seat
-J3 Khaki
AHCP Trailer Tow Group
AL1 Quad Cab Lone Star Value Group
APAS Monotone Paint
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BRTS Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CG1S Next Gen Multistage Front Air Bags**
CKES Floor Covering Carpet
CLE Front & Rear Floor Mats
CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CUMP Mini Floor Console
CUSS Overhead Console w/Trip Computer
CVHP Front Center Seat Cushion Storage
CVN Folding Flat Load Floor Storage
DGBS All 4-Speed Automatic Transmissions
DG8 4-Spd. Automatic 48RE Transmission
DH1S Man Shift-on-the-Fly Transfer Case
DJQS 5,200# Front Axle
DMES 3.73 Rear Axle Ratio
DRQP 11.50 Rear Axle
DSA Anti-Spin Differential Rear Axle
ETH 5.9L I6 HO Cummins TD Engine
GACS Tinted Glass Windows
GFDP Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNMS Passenger Side Sun Visor w/Mirror
GPG Power Black Trailer Tow Mirrors
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JAYS Instrument Cluster w/Tach
JBYS Instr. Panel Color Keyed Bezel
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKYS Power Accessory Delay
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JRDP Power Driver Seat
JTHP Power 6-Way Driver Seat
K1XP Jet Black - Molding - Bodyside
K17P Bodyside Molding
LMAS Halogen Headlamps
LNJP Fog Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MFDS Bright Grille
MGAS Ram's Head Badge
MHAS Black Windshield Moldings
MTDS SLT Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MYGP Lonestar Badge
NAA Federal Emissions
NFUS 34 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCS Heavy Duty Engine Cooling
NZCP Current Generation Eng Controller
PRH Inferno Red Crystal Pearl Coat
QRHS Inferno Red Crystal Pearl Coat
RAAC All Radio Equipped Vehicles
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
REFS AM/FM Compact Disc Radio
RSAP Sirius Satellite Radio
SBES Power Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TT3S LT265/70R17E BSW All Season Tires
TZHP Michelin Brand Tires
WF1S 17" Steel Spare Wheel
WGDP 17X8.0 Forged Aluminum Wheels
WLZC All Aluminum Wheels
WMJP Center Hub
XA8S Non Adjustable Pedals
XBSS Pickup Box
XEAP Tow Hooks
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XGWP Stain Repel Seat Fabric
X9AP For More Info, Call 888-539-7474
X97P 1-Year Service Provided by SIRIUS
YAAS Build To U.S. Mkt. Specifications
Re: Replacement for my totaled 04.5' [Re: Eric] #1438797
05/25/13 10:40 AM
05/25/13 10:40 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
So did you go get the truck yet???
Whats the update......... is it as good as it looks.
Just think - it's RED so you can easily hang out with Gorski cause he loves RED trucks
Russ
Re: Replacement for my totaled 04.5' [Re: Eric] #1438798
05/25/13 12:43 PM
05/25/13 12:43 PM
mopar65 Offline
mopar65  Offline
hey Eric if you join the ram truck site, which is free. It will tell you everything you want to know about your truck, like if it has any recalls, service, warranty history etc. enjoy your new truck. mopar65
https://www.moparownerconnect.com/oc/US/en-us/sub/Pages/OwnersLogin.aspx
Re: Replacement for my totaled 04.5' [Re: mopar65] #1438799
05/29/13 04:45 PM
05/29/13 04:45 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Thanks for the info ...Truck is home...very nice...I drove it three miles then hooked it to my trailer and went racing in NY...
