Anyone successfully repaired a cracked engine block? #1438551
05/18/13 10:29 PM
05/18/13 10:29 PM
Middleboro,MA
Jopar Offline OP
Jopar  Offline OP
Middleboro,MA
I rebuilt a 440 a couple of years ago and the builder discovered a crack on the drivers side above the freeze plug. He pinned the crack and didn't seem to be too alarmed. Now fast forward 5 years later I am on the home stretch and breaking in the cam and discovered a small leak coming from the repair. Is this repairable? The engine runs great with this exception...:( Any suggestions?
Re: Anyone successfully repaired a cracked engine block? [Re: Jopar] #1438552
05/18/13 10:33 PM
05/18/13 10:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Get some moroso ceramic seal assuming the crack didn't grow.
Re: Anyone successfully repaired a cracked engine block? [Re: Jopar] #1438553
05/18/13 11:03 PM
05/18/13 11:03 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Built a 390 Ferd for a local guy last winter.Bored, decked,10.4:1 comp,E-heads,cam,cleaned up, all assembled and ready for break in. Start it up and get steam pouring out of v.c. breathers after it warms up. Shut it down and finally find a crack on the inside of the lifter valley. Installed lacing pins and slathered it in J.B. weld and so far so good. Literally made me sick to my stomach when it started steaming.Those F.E.'s are expensive to build. Same block never leaked before cleaning it out in the tank.Must have broke a scab or two loose.Still gotta install his traction lock to cure his newfound "peg leg tire smokin blues"
Re: Anyone successfully repaired a cracked engine block? [Re: Jopar] #1438554
05/18/13 11:12 PM
05/18/13 11:12 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I have used this product with very good results. GM uses them for porosity issues.
http://barsproducts.com/catalog/view/6-radiator-stop-leak-tablets-hdc
Re: Anyone successfully repaired a cracked engine block? [Re: Jopar] #1438555
05/19/13 03:31 AM
05/19/13 03:31 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
There were certain years of 5.9 cummins known for cracking... do a search and you'll find lots of info on repairs.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Anyone successfully repaired a cracked engine block? [Re: Silver70] #1438556
05/19/13 07:10 AM
05/19/13 07:10 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Lock-n-Stitch is the best way I found to repair cracks. Fixed many rare blocks with this product.
