Re: Anyone successfully repaired a cracked engine block?
[Re: Jopar]
#1438553
05/18/13 11:03 PM
05/18/13 11:03 PM
Posts: 1,022 Andrews,In. U.S.of A.
67_Satellite
Built a 390 Ferd for a local guy last winter.Bored, decked,10.4:1 comp,E-heads,cam,cleaned up, all assembled and ready for break in. Start it up and get steam pouring out of v.c. breathers after it warms up. Shut it down and finally find a crack on the inside of the lifter valley. Installed lacing pins and slathered it in J.B. weld and so far so good. Literally made me sick to my stomach when it started steaming.Those F.E.'s are expensive to build. Same block never leaked before cleaning it out in the tank.Must have broke a scab or two loose.Still gotta install his traction lock to cure his newfound "peg leg tire smokin blues"
[Re: Jopar]
#1438555
05/19/13 03:31 AM
05/19/13 03:31 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
There were certain years of 5.9 cummins known for cracking... do a search and you'll find lots of info on repairs.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
