MSD Street fire Ignition module #1438409
05/18/13 05:23 PM
05/18/13 05:23 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Is it a good idea to upgrade my ignition system with this module? Local Pep boys has it on sale tomorrow and my ballast resistor is cracked anyway.74 360.
Re: MSD Street fire Ignition module [Re: cudabitten] #1438410
05/18/13 05:40 PM
05/18/13 05:40 PM
Indiana
Y
YO7_A66 Online content
YO7_A66  Online Content
Y
Indiana
I replaced my FBO ECU with the Street Fire box. It has a rev limiter and my car starts every time. I have been running it for about one year now and I like the idea of running down to O'reilly's for another one if I have any problems.
They do not require a ballast, just wire both the RUN and the START wires at the old ballast into the SMALL RED wire.
They are only a slight bit bigger than the orange box.
Re: MSD Street fire Ignition module [Re: YO7_A66] #1438411
05/18/13 05:47 PM
05/18/13 05:47 PM
Indiana
Y
Y
Indiana
It fits on the same mounting bracket as the OEM & FBO ecu.
Re: MSD Street fire Ignition module [Re: YO7_A66] #1438412
05/18/13 10:20 PM
05/18/13 10:20 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I swapped out my factory ignition for one. Had it on there since last winter. Probably put 1000 miles on it. No problems so far.
I haven't tested the rev limiter.
Currently 120 bucks on Amazon.com. I think I snagged mine for 80 bucks off Ebay. Pretty good value compared to the other options.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: MSD Street fire Ignition module [Re: 471Magnum] #1438413
05/18/13 10:35 PM
05/18/13 10:35 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I just picked up on from a member for 70 , I doubt it's got 50 miles of use ....
thanks Bob ...
Re: MSD Street fire Ignition module [Re: YO7_A66] #1438414
05/19/13 03:39 PM
05/19/13 03:39 PM
eastern, pa.
eastern, pa.
Thanks, I just picked this up for 112. I'm gonna mount it just like you did.
The guy had a demo set-up which compared the spark jump between a regular voltage regulator and this module they were very different, especially at the higher RPM. He also said something about how this throws sparks at a 20 degree radius or something???Helps burn off excess gases??? Not sure prob just some propaganda.
